FAA Part 135 IFR checkride in a 421C
avi8tor1983
I just recently got an offer to fly a 421 for Air ambulance/Charter. The only drawback of the job is a checkride with the FAA every 6 months as the company dose not have examining authority. I was curious what might be required on the oral portion? Thanks
is it 135, probably same ole stuff..(ie everything...lol) I would expect aircraft systems, procedures and op specs for the company....
Probably company specific stuff. Maybe for a .293 check once a year expect some aircraft specific stuff. For your .299 (probably combined with a .293 and .297 once a year), it's just A to B.
Know your GOM, your Op Specs, your reduced vis takeoff stuff, aircraft limitations, MEL, etc. You should be fine. The 421 is a nice plane. Quiet. Lots of people like to baby the engines only to end up destroying them, so just make sure you know what you're doing with them.
-mini
40k to start and its in McAllen isnt it? lol- I just turned down that same job if its the same one.
We also do our checkrides with the feds.
Our POI is about to change again and the oral changes a good deal between inspectors.
x2 to what mini said.
Our guy also hit stuff outside of 135 regs like "If you move, how soon do you have before you notify the FAA?" say wha...?
As far as systems go, I am pretty sure he just took my word for it, maybe not but he just gave off that vibe. The oral is going to center on op specs and GOM, but will vary with inspectors.
I wouldn't say it is that big of a negative.
I had to do a checkride for the feds (135 PIC) in a PA-31 and it wasn't bad at all. Expect to cover all of the items listed on the 8410. Essentially it's like doing an ATP ride... In fact it was exactly the same.
Well thanks for all the incite guys. I guess I'll find out when it comes time for it what will be for sure covered. I'll be going down to see where I'll be working on Wednesday this week. Its a great job and right up my ally so I hope I'll do well with the interview. I know there are a ton of apps for the job out there. As for the ATP check ride part I was told that too. I was told by the CP that I could even use the plane for free to take my ATP check ride so thats a plus. I'm about 40 hours away from 1500 though. Thanks for all the help again.
A quick dumb question. I don't think this will happen but what if you bust a 135 check ride with the FAA? I know about CFI because I've sent 2 that have busted and its just a recheck on area's deficient but what about 135? The same?
Pretty much.
You can also "suspend and retrain" on a 135 ride if the inspector is willing to do that. Things like screwing up the stall series or steep turns may get you the option to suspend the checkride, re-train on the maneuver and re-attempt it on the checkride before continuing.
Just try to be safe and hit MDA +50/-0 on your non precision approach and you'll be fine. It's a glorified instrument rating checkride.
-mini
Question from a guy who's never taken a 135 ride...what are the standards? ATP?
Typically. Though, IIRC, the difference between the instrument rating/commercial and ATP is only at MDA on the non-precision approach. You're still expected to be +/-100' outside the FAF and inside the FAF on the ATP ride, you're given +50/-0 vs +100/-0.
...that could be dated information though, I'm not sure if I have a current PTS downloaded.
Honestly, if you can't maintain ATP tolerances on a checkride, you probably shouldn't be flying 135 yet.
-mini
-mini
Well that's the thing. I strive for ATP any time I fly anyways I was just wonder how the 135 rides compared. The +/-50 for the MDA is correct.
I know of at least one company that has some sort of Approval to use commercial PTS tolerances for the 135 rides.........but again, I think the only difference is at MDA.
-mini
Pretty much.
-mini
That is not completely correct. A 135 check administered by a check airman can be stopped for an unsatisfactory maneuver, retrained, and restarted. An FAA inspector does not have that option. If a maneuver is unsatisfactory, the ride is unsatisfactory. If a 135 ride has an inspector observing a check airman, then the check airman rules apply and the retesting can be done, but that isn't the case when the inspector is administering the check.
Didn't know that. Thanks for clearing that up.
-mini
-mini
IIRC, I never read it anywhere but the chief told me that you are tested to the level of your certificate.
As in I'm held to commercial standards where one of my fellow pilots is held to ATP standards...if I remember correctly.
