PGT
Having never done any multi-flying this may seem like a silly question. But, how can engines be out of sync?
On props it's if the RPM isn't matched up, you get this really annoying "waw.waw.waw."
Interesting. I am guessing it is the same with jets?On props it's if they RPM isn't matched up, you get this really annoying "waw.waw.waw."
Any Airbus drivers know why, every once in a while in cruise flight, the engines start running really rough for a few minutes and then smooth out? It almost feels like when you get ice buildup on the fan blades (in a CRJ) but not that bad.
We are cruising along at 36,000 and it just started a few minutes ago, stopped for a while and then started again. I've noticed it on other flights too.
Anybody?
Engine synch usually works off of the right engine, why is that?
747-400 (CF6) has engine trim to sync N1s
E145 has the same
E170 also
747-200 has FE engine trim
No engine sync on any turbojet I've ever flown and I've flown the first generation jets right up to the most modern.
Not sure what sort of jets you been flying but as Polar and others have said, a bunch models do. Add to his list the CRJ700/900 which has the option of N1 or N2 syncing using the FADEC. On the small CRJ you have to manually sink the fans by adjusting the N1s with the thrust levers.
It's news to me that Airbus and Boeing planes (excluding DC-9s) have anything that keeps the engine RPMs balanced.
I am aware N1 trim values, but that is something specific to each individual engine. It is a schedule of N1 values that are empirically-derived in a test cell to relate the actual tachometer N1 to the "book value" N1 for the full range of thrust settings (ECAM/EICAS indications are normally the trimmed values). It is fixed in the EEC and (as far as I know) does not change while on-wing.
