Does the ORIGINAL Piper J-3 Cub have a built-in radio? What about a transponder?
For my introductory flight, I flew in a cub and there were no electronics, just an intercom thing the guy brought that was run by batteries. It made the skyhawk feel like such a technologically advanced airplane.Nope, no electrical system at all on the stock ones.
Unfortunately, many of the ones flying around today have radios, transponders, starters and all that other stuff that you don't need.
So does that mean the original piper cub is limited to uncontrolled airspace? What about if I have a hand-held radio? Could I enter controlled airspace?
With a hand-held radio you could operate from a class D airport (no transponder required)
If you want to fly in airspace that requires a transponder and radio it can be done in the cub. You would not want to make it a daily event but if you had to you can contact the controlling agency and give them the details of your flight. They will likely ask or tell you your route of flight and you will tell them when you plan to enter the airspace. They will track you on radar and be aware of your intentions.
If you want to make things even easier, if you have a hand held radio you can simply call the controlling agency and tell them you are negative transponder and so long as you have two way comm it will not be an issue.
I have done both on a few occasions.
But doesn't the cub have a starter that you don't need to start it with your hand? Why would I need to hand prop the cub in order to start it?
All of you guys commenting on how great it is to have no electronic systems just lost the right to complain about jagoffs cutting you off in the pattern with no calls![]()
<HR style="BACKGROUND-COLOR: #d1d1e1; COLOR: #d1d1e1" SIZE=1>All of you guys commenting on how great it is to have no electronic systems just lost the right to complain about jagoffs cutting you off in the pattern with no calls![]()
