It almost seems like it is easier to use a fixed card with NDBs. That way you are not constantly turning it whenever you change your heading, and you cant forget to turn it and confuse yourself. To each, his own I guess.Fixed card NDB does required SA and a good crosscheck, but isn't impossible IMO...just a little more workload. RMI....now you're good to go.
I agree completely. I never spin the compass card in an ADF. More workload for little gain. Easier for me to see the ADF for what it is...a device to show the a bearing relative to the nose of the aircraft.It almost seems like it is easier to use a fixed card with NDBs. That way you are not constantly turning it whenever you change your heading, and you cant forget to turn it and confuse yourself. To each, his own I guess.
Cool! Cant wait to fly A/C with an RMI.Once you try the RMI, you almost get spoiled. On the RMI, the card "turns" already, as it's slaved. And some HSIs have an RMI function incorporated.
What you were describing before was homing, if I read it correctly. It wasn't the being below MDA that necessarily killed that crew, it was homing vs tracking with an NDB, not having the minimum number of NDBs required for the approach in the first place, and executing the missed in the wrong direction.
Btw, I edited my initial post since when I reviewed it, it came across as somewhat negative, which wasn't my intent.
No biggie.
I can accept fair correction. (I'm also a charter member of the KYOA Club)
