Minimum SRS queries
freedevil
I was wondering if someone could tell me what the SRS requirements are after sunset. Visibility is 10NM and sunset has occurred. A CAT I aircraft is landing behind another CAT 1 aircraft. Prior to sunset its 3000 feet from the threshold, does it remain the same after sunset?
If a CAT II aircraft is landing on the same runway behind a departing heavy CAT III will the separation remain at 6000 feet?
Thanks.
Thanks.
I believe after sunset, the requirements are clear of runway.
But then again, I'm an Academy washout, so what do I know. :laff:
