Calling ALL A&P and Engine Guru
meritflyer
So, I have a pre-buy done today on a Turbo Arrow IV that I am considering buying and here is the mechanic's biggest concern.
In March '09, the turbo failed in flight. One of the turbo blades completely came apart and became a pile of metal dust.
The plane was landed uneventfully and taken in for the service to repair.
The plane received a new turbo after the cylinder walls, compressions, manifolds, and piston crowns were all inspected via boroscope with no defects. The turbo was replaced.
Now, the fun part.
The mechanic that put the new turbo in advises the oil needs to be changed every 5 hours for atleast 4 changes. The first three yield non-magnetic metal (not a good sign I presume) although he notes the metal is a result of the turbocharger failure.
In the last 10 hours, it's been clean including today when the mechanic cut open the filter during the pre-buy. The concern is, that there are metal parts floating around in the engine and may not be able to be detected and could cause piston and crankshaft failures (hope I said that right).
The owner is confident that it's not an issue as the metal in the filter was a result of the blade. The mechanics are being cautious but suggesting that it's probably not an issue but there's no real way to tell. They are going to pull the oil suction screen tomorrow for another 'gut' check but all in all, they said there's really no way to tell immediately if there's metal in the engine.
I need your input on this, folks! What do I do?
I am not a mechanic. That being said, this would make me feel much more confident. The engine has been run, the system is clean based on the checks they are doing which seem to be the only logical checks. How bout the pistons/valves though? If there are no unusual marks or grindings on those either I would presume you are safe.
If junk floating around in there hasn't damaged any of those parts yet than I can't imagine it would suddenly appear after 10 hours, 1800+ rpm average, or 1,080,000 revolutions of all those valves and twice that for each piston if I have that math right. Piston does 2 up and downs each revolution and each valve does one, right?
Unless the bearing or the compressor section of the turbo failed, there isn't really a way for metal from the turbo to end up in the engine. Anything from the turbine is just going to get blown out the exhaust. So my gut instinct is that this is not really something to worry about. Even if the turbo bearing toasted and bits of that got into the engine, that should be out by now (as evidenced by the clearing of the oil filter).
When they checked the filter, did they actually remove the element and soak it in solvent to let all the little bits come out? I've seen guys just look down into the cracks, and that doesn't really tell you much unless the whole engine is coming apart. I also doubt that the oil suction screen will tell them much...if there was enough to get stuff caught in there, then it would have showed up in the filter.
:yeahthat: +1. No way for the blade to make it past the rings w/out destroying the rings/cyl wall. If It's no making metal, then it's probably in good condition. Just make sure that if there is metal in the filter after it's been through solvent, that it DOES stick to a magnet. The bearings are made of non-ferous metals, and if they are comming apart, a magnet will not pick them up. A very small amount is ok, a large amount isn't. I would also recomend that you send the oil out and get it analyzed.
Yes, an oil analysis, especially if you can get one done of the particles from the filter, would be a good idea. How much TSMOH on the engine (not really relevant, just kind of curious)?
It was indeed the compressor blade that disentegrated when the turbo failed.
The major concern from the mechanics is that the metal could reap havoc on other internal engine parts if free metal parts are floating around.
Time on the engine is 990 since factory overhauled.
The issues discussed with an oil analysis is that it will take 100 hours or so to get a very good trend on whats going on.
In that case, if the cylinders and pistons have been thoroughly borescoped, I wouldn't worry about it too much. That would be the most likely location for damage by the disintegrated compressor blade. Again, it seems rather unlikely to me that even with a compressor failure you would get THAT much metal into the bottom end of the engine. Cylinders, pistons, and valves would worry me, but between the piston rings preventing stuff from getting into the bottom end in the first place, and the oil filter picking up most of the nasty, I think you are probably safe. That advice is probably worth exactly what you paid for it.
If the engine hasn't shown any damage since the turbo blew, it should be OK.
The entire intake manifold and cylinders need to be examined CLOSELY with a borescope.
If the oil analysis shows the metal content returning to normal, then you should be OK.
Make sure you know who is running the boroscope. I looked at a plane last week and 2 mechanics trying 3 boroscopes could not tell me anything. Neither of them knew how to get the scopes dialed in and giving good information.
I'd suggest an oil analysis also, so you can tell where metal is coming from.
