drunkenbeagle
Gang Member
In a 60 degree (2G) bank, the load factor doubles. Agree? The aircraft isn't actually any heavier, but for all practical purposes, the wing IS supportng twice the weight as in straight & level flight.
The wing in a 2G bank has two accelerations acting upon it. Gravity is one. The turn is the other. Acceleration, as we know from kindergarten, is the rate of change of a vector quantity (velocity in this case). It is the horizontal component of lift that is increasing the load factor. The turn is an acceleration, because it is changing direction. Centripetal force is a better term than load factor. And it is not directly related to bank, it is equal to the mass of the aircraft times velocity squared divided by the radius of the turn. (F = mv^2/r).
That is why it is called "load factor" and not weight. I blame the stupid US system for defining the pound as both the unit for force and for mass. Weight is by definition the force caused by acceleration due to gravity. The term can not be used to describe any other forces.
