mjg407
I will say my initial CFI-Multi was the hardest rating I ever had to get. My II was pretty simple, but my initial sucked. Here's part of the problem that we as military instructors will struggle at. Every student you see in the fleet, whether at a VT or FRS, has had an initial screening for aptitude. Not so in the civil world. So you need to learn how to teach at that level. I would say if I had VT experience, it would have made it easier, especial the ground part. Also, learning the FARs suckked! 3710 makes a lot of sense to me, and there is very little exceptions, not so in the FARs, for almost every rule, there is an exception.Doesn't that apply to anything? My point being is I would say most military pilots shouldn't have a problem transitioning to the GA side of the house. Not hard but granted, having an understanding of the type of flying would be key. I for one would not want to instruct or give check rides in aircraft that I was unfamiliar with, don't care if it's something as simply as a C-172. I might have 3000 military hours, 600 carrier landings, both prop and jet time but a competent instructor pilot with many hours in the C-172 is going to initially fly it better than me (or should in a perfect world), hell may even be better period with enough time and experience.
