Don't worry, it won't happen again.Hey, its awesome that when someone tries to post something to help others out, they get snide comments from the mods.
-mini
Seriously?
...this is the hot topic of the day?
I could think of more pressing issues than graphics in signatures, but that's just me. If you don't like 'em, you can disable 'em in your "CP".
-mini
If you don't like seeing it, follow along.
Top left of your screen, click "User CP".
Left column under Settings and Options click "Edit Options"
Scroll down to the box that is labeled Thread Display Options and uncheck the box that is labeled "Show Signatures".
Scroll to the bottom of the page and click "Save Changes".
Your problem is solved.
-mini
I was honestly just trying to help out. Not everyone may have realized you could hide signatures. *edit* Or "opt out" of PMs, images (behind an [ img ] tag), etc...
My sincerest apologies for trying to help at all. Please continue with resolving life's big issues one at a time and I'll just sit on the sidelines to watch.
-mini
It was both. Honestly I can think of bigger issues on the boards than graphics in signatures, but if we're going to discuss it...you can just disable them using your user CP (my recommendation to help).Doug asked a simple question and in your 1st post you really don't seam to be offerring any help. Seems to be more of a snide remark to Doug.
I saw it as a pathetic effort at masking an insult. As for relaxing, you might want to try the same there, chief.Geez....Dude relax. A little thicker skin might be in order....Did you miss the sarcasm at the end?
It's going away. Hopefully it's an endangered species.Minitours have blubber? I learn something new every day.
I didn't either, but like you said...whatever.I saw no problem with your post, but what ever. The one thing is that that will disable the entire signature block and not just giant useless images contained their in.
That was either a really short time on dialup or a really really really long time.back in '96-96 when all of us were on dialup.
It will disable the signature unless they're put in with an [ img] tag or attached, then you can just un-check the box next to "Show Images". It's two below "show signatures", I believe.
-mini
PMs are turned off and e-mail should work. I'll check on my end to make sure it isn't a problem with the provider (they kinda suck).
-mini
-mini
