http://www.airlinepilotforums.com/flight-training/41468-cessna-v-piper-trainers-4.html
Post #32 is where he starts to answer this for us...or does he?
I'm not sure there is any real disagreement in that thread.
There seems to be a misconception that an increase in a specifc C/L is a total increase in lift... this is not true... total lift can only be increased when C/Lmax is increased
Here are the other two maybe this will help:
ryan1234 started off okay, but then went off into Looney Tunes land. You won't reach any understanding with him.
How would you change CLmax? Every time I've ever looked at a CL graph it's always a fixed angle of attack the generates the greatest amount of lift.
Cl max can vary with airfoil design. I don't have access to the formula, I have one advanced book that likely has it but I wouldn't have the slightest idea where. Basically Cl max is figured out for each individual wing (right?) during testing. If I remember right it can vary 14-17 degrees and I have read 18 but I think you get the point, wing design varies Cl Max.
they are just the other factors that cause lift: impact, bernoulli, and deflected air.
The theoretical determination of lift on an airfoil is based on the sum of the pressure differences around the airfoil, and those pressures will be related the velocity of the air via the Bernoulli equation.
So what exactly is Cl measuring than?
Let me see if I have this right then, impact lift is nothing more than a pressure applied at a point on the airfoil. Lift is a measure of that application of pressure which is sometimes confused as a separate entity?
The same would hold true for downwash or deflected air? Where ever the pressure is originally applied to the airfoil is what is measured, not the force it exerts downward. Am I on the right page?
The deflected flow is a result of lift, not the cause, but you probably could calculate the quantity of lift based on the quantity of air deflected.
What I meant was that the deflected air exhibits some form of pressure on its point of impact (really the point of deflection around the wing) and that pressure is calculated for? That help.
Not really. It's just a number that relates lift to dynamic pressure and wing area. You can plug that number into other formulae and get actual physical quantities, as long as you supply some other data along with it. Sorta like glide ratio or propeller efficiency.Cl is basically calculating the pressure differences then?
But it is a theoretical number, not an absolute? I say this because the rest of the lift formula is air density, speed, and wing area. Cl would be the only one capable of attempting to calculate the pressure differences that I can see.
Tgray, or some other dynamics guru please take a look at this: http://www.airlinepilotforums.com/technical/42432-lift-ground-effect-continued-3.html#post655599
Specifically the last two paragraphs. I have been rereading this over and over and it still doesn't make sense, I wonder if anyone can shine some light on this in more lemans terms, thanks.
That post is your own post. Which of your own paragraphs confuse you?
(Ryan, BTW, is confusing absolute AoA with effective AoA.)
Also would you mind making some attempt to explain this: http://www.desktopaero.com/appliedaero/airfoils1/tatderivation.html
