Recording Lessons
mngtsystem
Hi there:
I was wondering if anyone knew of a good way of recording (audio and visual) one's lessons to be able to review them when done. I am trying to figure out a way to record both the ground school and also the flying the portion of the lesson (with the ability to record the audio too). Any suggestions would be great! Thank you.
I don't know what they're called, but the box looking thing you can plug your headset into to listen to like an ipod or something, you may be able to find one that has an output as well as an input jack (or rewire one if you know how) and then record an audio track from that. At the same time record a video then put them on your computer and lay the audio track on top. Or just switch to a really quiet cockpit. Good luck lol
I have a recording device that has a mic input and all I did was go to radio shack and buy a lapel mic ($10) and take the clip off of it. I just stick the mic under the left side of my headset. I don't notice it and it works perfectly. Pretty rigged up, but hey it works right? :)
RD
There is a podcast I listen to that is called "The Student Pilot Podcast" and the website is http://www.studentpilotcast.com/cast/
He records and plays it on the podcast as well as listens to it for his own development/review purposes. There might be a page on the site saying how he does it or you could email him and he could tell ya.
Buddy of mine used to use an adapter for his camera to go from the headset plug to the audio in. Worked great and only recorded intercom/tower transmissions.
I've used http://www.aircraftpatchcord.com/ It works very well - everything you hear through the headset is captured. My setup was to get a BESSEY Metal Spring Clamp from Lowes. Remove one of the orange sleeves on the handle and the hole already there will work nicely with a (I think) 1/4" screw which fits perfectly into the tri-pod connection on your camcorder. Clamp to panel and film. To add adjustability, I bought a mini tri-pod and took it apart and used the swivel head between the clamp and the cam corder. That way, I could clamp to the back seatback (clamp pointed down), adjust camera up and forward.
For $35... makes my $10 rigged up version is well worth it... :)
RD
I had a student record his training, and create a podcast:
http://web.mac.com/shagswell/iWeb/T...light PodLog/Student Pilot Flight PodLog.html
He then continued on with some stuff after getting licensed. He used a mic in the headset. Allows to hear engine noise changes, and stall warnings, etc. that don't always come through and break squelch if you tie directly into the intercom system.
And now, he is filming a nice movie:
http://www.apilotstory.com
That is who told me how he did it and I adopted it and posted it here. Should have given Will credit in my first post.
RD
