In the turbo cirrus, which is normalized, you do nothing. Just start your descent and if you need to pull back a few % power to keep the speed down out of the red you do. But at 85% power you can make a 500 fpm descent without changing anything. You are way over tubulence penetration speed though, so if it is rough or IMC I do not do this. If it is rough I will pull it back to about 65-70% and make the descent. That is the beauty of the cirrus normalized system, I can descend from 25,000 feet and not once touch the mixture or the throttle until on approach. The same goes for the climb, mixture full till level off, you lean the mixture to 17GPH fuel flow, and it is set, no matter what altitude you climb to. You just make minor changes(+/-1 GPH) based on CHT.
Yup
