In a "proper" descent where you just power back and airspeed remains the same how can you apply 2 cooling actions at once? Unless the CFI's descent procedure was to throttle back and dive bomb the deck, then 1-2 inches might be worth thinking about.
Here from an article:
"(A Lycoming Flyer article once stated: "Engineering tests have demonstrated that valves will stick when a large amount of very cold air is directed over an engine which has been quickly throttled back after operating at normal running temperatures." See 101 Ways to Extend the Life of Your Engine, page 96.) But it's a big jump to go from that to saying you can make a cylinder head crack just by pulling the throttle back too quickly."
This article:
http://www.avweb.com/news/maint/182883-1.html
It all falls back to know the limits of degree change per minute on your CHT and stay within those limits, if you do that the procedure you use to do it is completely irrelevant. But like USM stated repeatedly, a 500 FPM descent (a reduction of about 5MP or 500 RPM or any combination of the 2) will not put your aircraft in any situation where shock cooling is an issue. Shock cooling is a factor primarily on cold days with high speed descents and the power at idle, my advice, stop worrying about it.
