Lesson Learned & a Pair of Boxers Later
PA-28-181 Archer and it does have a backup vacuum pump but it wasn't a vacuum problem I am pretty sure it is a Gyro Problem.
It's weird that it became erect again when you throttled up... but then again, it was isolated to that instrument... (cue Twilight Zone theme)
Any chance of it being a vacuum regulator problem? I'm not familiar enough with the system to know if both pumps are tied through one regulator or if they're completely independant.
Either way, good job bringing it home.
No I didn't have a cover and it was totally disorientating. I am still going through my mind what could of happened. The ATT was not to far off it wasn't very drastic at all however it was wrong from cross checks which made me freak out a little. Vacuum was in the green and the DG appeared to be working properly. My question is why didn't it get way off. It was almost like the bank was 15 degree's off and the pitch was about 10. When I landed from the point of pulling the power back on the APP the ATT indicator was all over the place but when I ran it back up after like 2 min it became erect again. IDK I just keep playing the situation over and over in my head and even though I shoot the APP to basically ATP standards (lateral and vertical) once established I was completely behind a very easy airplane. My airspeed was fluctuating between 90-110 just because I was diving and driving and my ALT control in the turn and decent was just awful. I am going to be beefing up in the sim the next couple days just because I am not happy with where I am at right now and feel I should be at a higher standard especially since I am teaching this stuff.
Thanks for reading,
jhugz
I'm not intimately familiar with that system, but it's possible that the problem was between the vacuum gauge and the AI. It also could be the AI itself failing. I've seen them start to go like that, just a little off.
I've also seen gyros start to go like that. Pump works fine, but the gyro won't say erect. First you get the thing leaning to one side or the other, and eventually it tumbles.
Good job getting it on the ground.
I know how you feel with the scary situations. I've had the "pleasure" of having one in my short training and you can't help but think how much worse things could be.
Let's just say I need more work on x-wind landings and that I found a way to practice hard-surface runway landings and soft field landings simultaneously.:banghead:
Well played!
You're not the first, you won't be the last. The plane ok?
It may not be the gyro that is shot. Sometimes other parts will die in the attitude indicator. I have almost gotten sea sick once because the gyro worked but a spring or two went bad and the AI was waving back and forth. I have seen that failure twice, luckily not in IMC though.
I guess it doesn't really matter whether its the gyro or some other interior part. There's nothing an A&P can do other than swap out the inop one.
It didn't get way off because that's how gyros fail. They're not like lightbulbs which work perfectly until they fail completely. Gyros generally die a slow, painful death.
The plane I did my IR training in had a failing AI for about 1/4 of my training. In that case, the AI wouldn't go upright and correct until about 10 minutes after the first takeoff. So the first takeoff would have the AI showing a 30­° decsending turn and for the first part of the flight. Then it would right itself and behave normally until shutdown. Since we were VFR we took advantage of it as a training situation. I would go under the hood at 100' or so on the first takeoff while the AI was still waking up. We left the AI uncovered and I just had to fly it that way. It was great practice for learning to ignore the failed instrument without having to cover it up.
The dude admits he learned a valuable lesson and you decide it's a priceless opportunity to shoot a volley at him. Are any of you parents/planning to be parents? I hope you don't talk to the little 2yo monster like that when they approach you and admit the value of a recent success/failure. Priceless opportunity here.
I'm pretty sure the OP isn't a two year old kid. And I'm pretty sure this is the Internet and not a face to face interaction. If you do not understand the fundimental differences which those two points bring to this situation, then perhaps you are the one who has missed a priceless learning opportunity.
