Interesting articles (from an e-mail safety update, hence no links):
Honeywell Recorders Probably Pinging as French Search for Jet
June 4 (Bloomberg) -- Honeywell International Inc.’s so- called black box recorders on Air France Flight 447 are probably signaling investigators from the bottom of the Atlantic Ocean. The trick is figuring out where to listen.
The data and voice recorders on the jet that crashed off eastern Brazil on June 1 with 228 people aboard have a water- activated “pinger” that runs for 30 days. Honeywell certifies that the boxes will remain intact as deep as 3.8 miles (6.1 kilometers), about twice the depth of where French officials estimate the wreckage to be located.
“We expect the box to be pinging,” said Bill Reavis, a spokesman for Honeywell Aerospace Inc. in Phoenix. “The box is configured to withstand a high impact.”
Investigators are concerned they may not find the signal because the ocean is “not only deep but mountainous” in that area, Paul Louis Arslanian, head of the French Aviation Accidents Investigation Bureau, told reporters yesterday in Paris. The inquiry “is difficult, but not the most difficult we’ve ever had,” he said.
Searchers will probably use underwater microphones to help track the signal, among the processes that often prove successful in locating debris, said John Nance, who runs a Seattle aviation consulting firm under his name. The recorders are likely to be found as well, he said.
“Those things are almost indestructible and they almost always find them,” said Nance, a retired Air Force and commercial airline pilot with 40 years of flying. “If they can narrow down the search field and bring in the right equipment to hear it, I think they’ve got a good chance of finding them.”
Underwater Mountains
The strength of the audible pinging signal may be affected by colder water near the ocean floor. If ocean temperatures are constant, a pinger 2.8 miles below can be heard from the surface, said Reavis, who wouldn’t speculate on whether the boxes will be found. In this case, with varying water temperatures, searches with underwater microphones may be necessary, he said.
Investigators will have to contend with “constant” severe thunderstorms at this time of year, with wind gusts to 50 miles per hour that whip up high waves, as well as underwater mountain ranges, said Henry Margusity, a meterologist at State College, Pennsylvania-based AccuWeather.com. “It’s a hilly area on the ocean floor, with some trenches that go deeper and some shallow areas” that are only a mile deep, Margusity said.
The Atlantic is about 2 miles deep in the search area, according to AccuWeather.com, which gathers data on weather and topography. Searchers are focusing on an area about 400 miles north of the Brazilian island of Fernando de Noronha, off the coast of the country’s northeastern tip.
Mini-Submarine
France is sending a mini-submarine to the site that can dive 3.7 miles to recover data recorders once the wreckage is found, Energy Minister Jean-Louis Borloo said yesterday.
Searchers will combine calculations of currents with scanning the ocean floor, said Richard Healing, former National Transportation Safety Board member and now a senior partner with R Cubed Consulting LLC in Alexandria, Virginia.
“They are going to be able to use drift patterns and currents and winds on the surface” to find the wreckage, Healing said. “They should be able to go back and create what they believe would be a good starting point to look for debris. They can do bottom mapping, using sophisticated sonar.”
Earlier Crashes
The NTSB has located “all the recorders from airliners that crashed into the sea in the last decade or so,” said Ted Lopatkiewicz, a spokesman. At least one recorder was retrieved from about 16,000 feet below the Indian Ocean after a South African Airways Boeing Co. 747 crash in 1987, he said.
The recorders are designed to withstand 3,400 times the force of gravity on impact, Reavis said. Honeywell, based in Morris Township, New Jersey, is not actively involved in the search at this point, he said.
The black boxes are actually painted vivid orange to stand out from other equipment housed in black or gray casing. They are bolted to the frame of the aircraft near the tail and data have been recovered even when the inside is wet.
The recorders for the deadly February crash near Buffalo, New York, of a flight operated by Pinnacle Airlines Corp.’s Colgan unit were retrieved.
Seeking ‘Pinger’
A U.S. Navy ship found the flight data recorder of an Indonesian jet that crashed off the coast of South Sulawesi in January 2007, 24 days after the accident. The wreckage was on the ocean floor in 6,000 feet of water and the boxes were recovered “because the pinger was doing its job,” Reavis said.
The data boxes were retrieved in the ocean-floor wreckage of TWA Flight 800 that crashed in 1996 off the coast of East Moriches, New York, after a fuel-tank explosion, and the quality of the recording was “good” even though the magnetic tape used at the time was wet, according to the NTSB report on the incident.
The recorders from Swissair Flight 111 that crashed in 1998 near Peggy’s Cove, Nova Scotia, after an in-flight fire were also found, though a power failure stopped the recordings about 5 minutes before the plane went down, according to the Canadian Transportation Safety Board report.
The black boxes of the jets that crashed into the World Trade Center towers in New York during the terrorist attacks of Sept. 11, 2001, were never found.
The recorders’ capabilities are “vastly better” than 20 years ago when they included magnetic tape-recording devices with moving parts, said Bill Waldock, a crash investigation professor at Embry Riddle Aeronautical University in Prescott, Arizona.
“If they’re able to get a lock on the pinger in the next couple weeks, chances are pretty good they’ll find them,” he said.
France orders deep-sea vessel to A330 search area
France's ministry of transport has dispatched a research ship to the South Atlantic with equipment capable of searching ocean depths up to 6,000m (19,700ft) in a bid to recover any wreckage from the missing Air France Airbus A330-200.
Brazil's air force has located debris, including an aircraft seat and oil traces, around 700km north of the Fernando de Noronha islands, which increasingly points to the destruction of flight AF447 from Rio de Janeiro to Paris.
A statement from France's transport ministry says a research and exploration ship has been ordered to the area with immediate effect in order to set up a local command centre in the framework of the continuing search.
"This ship carries...heavy equipment capable of going to 6,000m depth and able to explore more than 97% of the ocean bed area, specifically in the search area," says the ministry.
Source: Air Transport Intelligence news
