AT-SAT on June 8th!
Bsmiller05
Well, I've been studying the green book and have been talking to quite a few controllers. Any other tips/pointers/etc that I need to know before the big, 8-hour day??
there's a whole thread that's stickied with things you need to know about the AT-SAT.
1. know the distance formula
2. try not to crash planes during ATC scenarios
3. have a general knowledge of angles
4. don't forget to order more boxes during the letter factory
5. try not to crash planes during ATC scenarios
6. try the ATC scenario and scan games from jeremy justice (http://www.jeremyjustice.com/games/index.html)
7. make sure you are comfortable using the 10-key number pad for the scan portion of the test, I saw people not using it and they were doing horrible.
8. relax, don't worry, and take your time, you've got PLENTY of it.
i crashed a ton of planes adn i still did fine
my brain was fried and i walked outta there discouraged but i still did well
youll be fine!
It was the questions during the letter factory that got me, but I really don't think there is any way to prepare for those. You can either do that kind of multi-tasking, or you can't.
As far as the ATC scenarios, my biggest mistake was not knowing exactly how close a plane had to get to something before it blew up. I would have the plane pointing at an airport to land, waiting to slow it down until the last second, and then it would run into the airport before I slowed it down.
The jeremyjustice game is very good for seeing how it all looks and works, but for the minute little details, it's not quite perfect.
the jeremy justice version of the AT scenarios isn't perfect, but it's pretty good, and it does a good job preparing you for the formatting of the actual test. the scan game is exactly the same.
From what I remember, the scan game in the actual test changed the range of numbers more often. And they also moved. Don't they stand still in JJ?
I'd have to say this is the most "to-the-point" post about the AT-SAT I've seen in a while. Well said.:yeahthat:
Isn't there a sticky thread devoted to this subject?
that was the first thing I said in my initial reply ;)
I didn't notice much of a difference if any at all in the number range changing in the test in comparison to JJ, I actually found the AT-SAT version easier...and no, they don't stand still in JJ.
thank you :)
You're welcome. And you're lucky.. I would have killed for Terminal in Western WA. I lived in Puyallup\Buckley years ago. I miss the PNW.
Puyallup is a pretty nice area, not too small, not too big. I don't know that my selection is for western washington though....
Ouch.. Spokane isn't that bad either though.. Just not near as scenic as west of the Cascades
yeah, I'm not complaining, I love eastern washington, and western washington is only a short drive away(unless it's close to a holiday and I have to go over the pass). living there will be realllyyy nice as far as traffic goes, king county has horrible traffic. I also like the fact that the weather is more seasonal....oh, and it's not going to be GEG either ;)
So the AT-SAT was this past Monday and between the nerves and lack of sleep, I scored an 88.8. Even still, that's considered WQ. So, even though it could have been worse, what are my chances of a job with that score and my ratings (comm multi/instrumet)?
My initial thought is, who knows how the FAA picks people. But that aside...I'm pretty sure there was a guy in PUBNAT 5/6 who scored an 85.4 or someing and got picked up. I don't believe the hype about higher scores within Q or WQ being looked at first, neither do I think experience/schooling matters much either (other than the basics they require to apply).
I'm thinking it's more like putting all the apps on a wall and throwing darts to see who gets a PEPC invite. But good luck and don't give up!! It's been 16 months since I started this process and it's finally happening. :)
How the hell did you already get your score back?? It took 2 weeks to get ours!
Check my signature... I'm headed to SUS with an 87.2. It can happen as long as there is an availability at a facility in your geo prefs.
I got my score back the next day....
congrats on the WQ score
Why is everyone always hatin' on my score? :D
My motto is do just enough work to get by. Had I missed 1 more question I probably would have faded away in the Qualified section.
