tgrayson
and was able to get an elevator stall,
It isn't an elevator stall, it's the very opposite of a stall. The AoA of the horizontal stabilizer is reduced, not increased.
First, you are correct that it is not a limitation. I've seen "avoid prolonged slips with flap extended" placards, but the manual says the plane remains controllable.
Now is it a good practice to have these pitch oscillations? I think a good landing follows a good approach, and if I screwed up that bad, I think I would just take it around. That is, unless there was a real compelling need to get on the ground right away.
I know a guy that busted his part 141 CFI initial checkride at American Fylers. He was inbound on approach with 30 degrees flaps and the examiner asked if he could demonstrate a slip. He does so and the examiner busts him for it and has him read the placard. Fair, eh I don't think so, but with some the distinction is not that big, and they would err on the side of caution.
I don't generally agree with tailoring one's instruction to match the ignorance of someone else. The only people that can really police the examiners are the instructors, and for us to put up with that sort of behavior from examiners tends to encourage it. The instructor in that instance should have gone to the examiner's POI and expressed dissatisfaction not only with the examiner's expertise but also his integrity.
Dude I am no expert in checkride gamemanship. That said, I really don't like checkrides, but have never failed one. In my opinion, you handled it right by wanting to follow the manufacturer's recommendation. As for the behaviour of the examiner, sheesh I hope I wouldn't be put in that position. Did you acquiesce or did you stand your ground? Outcome?That's sux, on my private ride, the examiner ASKED for a slip with full flaps extended. I told him that that was not recommended and he about bit my head off. He screamed, SLIPPIT DOWN!!!!
But you can be busted for showing poor judgement in the examiner's estimation, no?
My gut reaction to the story was that is was way unfair... But is was AF CFI academy 141 program, and I was told that it was against the FOM or company rules. Not sure if it was a Fed, DPE or AF check airman.
Says who? Got a referrence? Case history? Any kind of precedent?Right, I understand that, and I think you were replying to the other person who replied there. I know that you can do it in whatever you want to do it in, but if the NTSB or FAA gets involved in something, and the x-wind component is 18, you're screwed.
If you bend an airplane during a crosswind landing, I don't think you'd be any more screwed at 18kts than you would at 15kts. Pilot error is pilot error and the max demonstrated is not a limitation.
So you're making a claim about what the FAA will violate a pilot for and yet you admit that you have no idea what you're talking about. I've never heard of the FAA going after a pilot for exceeding the max demonstrated crosswind component. If you have evidence that they have, bring it. If you don't then please stop spreading myths about what you think they'll do.Obviously I don't know, and never care to find out, but basic common sense would dictate that would be the case
There are far too many myths and misunderstandings in aviation as it is. We don't need more and we don't the existing ones reinforced IMO so I call them out when I see someone who is guilty of same. If that makes me a bad guy them I guess I'll just have to find a way to live with myself.Slow your roll man... He is just stating what usually happens. When you bend an airplane, if they don't violate you , or make you take a 709 ride, your lucky, and an exception to the rule. No need to get all violent.:whatever:
