I've noticed that most LSAs are equipped with a Rotax 912 engine. I've noticed that it's RPM is higher than most conventional aircraft engine. For example, the RPM for a 912 can go from 5,000 to 6,000 RPM, whereas Continental O-200 engine can go from 2,000 to 3,000 RPM. Why is that? Both have the same 100 hp. Even 80 hp engine has a 5,000 to 6,000 rpm I think. How can the 80-hp engine have a higher RPM than conventional piston engines?
Second, why are some LSAs especially some modern LSAs measured in mph instead of knots? I thought knots was the standard measurement for airspeed? Is it possible to take a mph airspeed indicator out of an LSA and put a knots airpeed indicator in? Is there an option when buying an LSA to be measured in knots instead of mph?
