TUCKnTRUCK
That guy
Did they specifically remove that approach, or the circiling approaches all together,  I know they stopped training the IFR circles, so they have been removed from our opspecs
			I know I have seen you guys at DCA. How about the RV 19 at DCA?It's a damn shame. That was one of the few really fun approaches we get to do, if not the most fun on the Saab. There are pretty much none on the Q, unless you count the PWM harbor visual.
Right, but it'll remove it from the ATP. Odds are pretty slim of me flying a CRJ overseas right now anyway.
Kind of dbag for the SKYW van not to wait for you. We fly into the same airport at the same time, and stay at the same hotel as Lynx and we always make sure the van waits, and they do the same even if it is an extra 10 minutes. It's courtesy.
Way to make an ASSumption. Maybe the van was too small for a second crew, maybe they didn't know the other crew was coming, maybe they didn't know the other crew stayed at the same hotel, maybe the van driver didn't want to wait.
I'm guessing if the ATP is earned in an aircraft with that restriction, then it would carry any restrictions of that type. The checkride does not incorporate circiling manuvers under ifr, so I assume the limitation is on his ATP
 Wouldn't that just suck?
  Wouldn't that just suck?We just stopped training the manuver, so we will also carry that limitation unless you are already an ATP, or were brought over in the first year of the program. The ironic thing, is that Q400 FO's are already typed with the IFR circle, If they upgrade in the airplane, their ATP will be limited, but not their typeWouldn't that just suck?
Yep. It's listed twice under "limitations" on my cert: once for the ATP and once for the CL-65.
The actual type won't change, so they will be authorized to cirlce the Q in a non ATP duty.. but they will not perform the circle to ATP standards on their ATP ride, I've got a feeling the FAA won't let them do it from the left seat suddenly, but I would hope that it would transfer over... or that they forget to add it as an oversight. It's pretty stupid if you ask me.
Not that they should ever need it, but, It helps with the understanding and performance of the aircraft... and could be valuable in an emergency... I would rather see it trained, but prohibited via opspecs.
...but, if the type is not a SIC type, they already demonstrated it to ATP stds, thus passing the type. Just like my commercial type was given ATP privileges when I took an ATP/type ride in another plane.
Don't forget this thread when one of them slides over...
The FO checkride as I recall, only holds them to commercial pts... I haven't bothered to look to see if it is an SIC type, but I have a feeling it's just a type cert. for the DH8, They are also not required all the manuvers of the ATP ride on their type.
It will prob. be interesting to watch as they try to figure it out
If it is a PIC type, it is to ATP standards. Same PTS even.
