oktex88
Why does the Manfiold Pressure increase when you decrease the RPMs using the prop lever on a constant speed prop?
For example if I set my Manifold Pressure to 15" and bring the RPMs from 2700 to 2500 using the prop level then my Mainfold Pressure goes up to 18". Why does this happen, becase the engine should still be producing the same amount of power?
