Complex Endorsement Training Time
I dont buy into that statement! I hear it from time to time, but IMO being in a gear up accident is not something I believe WILL happen to everyone who flys a RG aircraft.
I can't believe how many people took that statement as being 100% literal.
:confused:
Who in aviation believes in anything 100% of the time.
post #11 "student would get their endorsement at the end of the 10 hours"
I didn't read that post as saying that someone thought a pilot needed 10 hours, just that the flight school required it. A lot of FBOs have a 10-hour time in type or 10-hour dual requirement for soloing in a complex - usually based on insurance requirements.
Maybe you're right and the school actually had a rule that said that one of their CFIs wasn't allowed to give the endorsement until insurance requirements for solo in the school's airplanes were met. That would be a bit unusual and I'd agree with your criticism of it.
:confused:
I believe everything 60% of the time, EVERY TIME!
Seriously though, this is how easy it can happen, what's that loud annoying buzz? If you listen close enough, I think they are talking about a phone number. Also, notice how the engine is running and how uneventful the landing is. Don't cut the engines!
[yt]Mle7DxDgQfg[/yt]
That is a good video.
Three in the plane, and one actually video tapes where the gear are supposed to be.
I always think that he says, "I went back there, the day after to find my gloves that I left there..."
If that is what he said then there is no way it wasn't an accident.
As far as I know,most singles don't feather, so you would still have a prop spinning into the runway, therefore still damaging the engine, so on a single whats the point.
:yeahthat:
Excellent observation. Stopping the prop usually takes a very slow speed and/or high angle of attack not to mention the time to accomplish plus bumping the starter to put a two blade prop horizontal. Not a good choice close in.
I really can't tell, either way it was a definate goof-up. I feel pretty bad for the guy when he slaps the top of the panel. That can't be fun.
I show that video in Brewmaster's post to everyone of my complex students on the first lesson. Mainly to demonstrate why I don't want to hear the gear horn without something to remedy it (ie power off 180... bump the power to 12in or drop the gear) Gear horn desensitisation is always a fear in the back of my mind. That video shows you how bad it can be.
Great thread, some really informative stuff. This is why I really enjoy coming to this place. On a side note all ATP mills tell you to try and save the props on a forced gear up landing. If I remember correctly they even make sure you can recite that before they send you out on cross country without an instructor. Tells you something about their priorities.
Where and who told you this nonsense? Never have I heard this from anyone at ATP, and I damn sure didn't teach it there.
We had the conversation when I was at ATP, but ultimately came up with the leave it running train of thought. The biggest problem at the time was the King Air that landed gear up at FTY (youtube) shortly before I was there and feathered both of his props, and landed perfectly. We decided he was just a badass and we weren't remotely prepared for that maneuver. It is a good video, but not something that should be taught in the context of this thread (giving someone a complex endorsement)
Then again for you to hear that all it would take is one instructor mentioning it to you. I'm pretty sure its not taught in Standardization (not sure though, never instructed there)
ATP SUA - initial multi through 302 ride i believe it was called,
Fulton County ATL - from both management & instructors during cfi school
I may have misled with my initial post that they forced this on you as a part of the procedure, but more so encouraged it if the situation permitted
I have a question that may or may not add to the discussion. Would it be possible that a spinning prop, multi engine or single, could have enough force on impact with the ground to flip an airplane? This could be either a roll or possible impact the ground and cause the plane to tumble.
If it did, gear up landings in a prop airplane would result in airplanes flipping over almost every time.
Not likely. The prop will bend first. BTW, I tried to finish the complex/high perf. endorsement with a student yesterday, I distracted him and pulled the breaker for the gear pump, and had to take the controls at 150 AGL. Why do some people just not seem to get it. If you pull the lever, and don't hear the pump----SOMETHING IS WRONG. Does everyone else teach to leave the hand on the gear lever untill the gear is down and locked?
I didn't really think it would matter much but its still one of those things that just runs through my mind when contemplating the possibilities.
And I always teach to leave the hand on the lever until 3 green. In my case in the seneca it's '3 green, no red, one in the mirror' with the hand on the lever
Yep.
On the hear the pump thing, I think the point is that there are a number of things that occur when the gear comes down - lights change, pumps and motors run, drag/airspeed changes occur, moment and pitch changes occur, etc. You focus first on the pump sound; I tend to focus first on the drag changes. We both use the tactile reminder of hand on the gear handle until the change is complete.
I think the ultimate goal is that the pilot should be made aware of all of the changes that occur so that multiple senses are brought to the task of monitoring the gear coming down. Which one or combination of clues will be the key for a specific pilot will be to some degree be based on that individual's internal wiring.
Now those would be some serious turning tendencies. :D
The DA42 it's really easy to hear the pump. The Duchess, I never did hear that thing...the rest of the airplane was too loud.
To say every student needs 10 hours for an endorsment is incorrect. That is a "school rule" to CYA for insurance purposes. He has no plans to fly the arrow after his endorsment from what you say. That means you can give him his endorsment whenever you think he has mastered the little up/down handle and the little prop handle.
I went from a C-150 to a mooney. I had my endorsement inside of ten hours! If/when he is capable and safe to fly the plane, sign him off. If he is a smart man when he buys his cessna he will hire you or another cfi who has experience in that type of plane and retrain in THAT plane!
Correct, I've given someone a complex endorsement in 2 flights -- but then I told them that our insurance requirements required 10 hours of dual prior to solo, but they did have the endorsement!
