dcramer16
I saw this on avianation.com. Not sure if it's a re-post of an old job, or if they are indeed hiring again, but here you go.
Job Code: 11
# of openings: 1
Description
PILOT
Job Objective:
Pilots are responsible for safe, economical, consistent and legal
operation of Company aircraft. They are required to comply with
all applicable federal regulations as well as Compass Airlines
policies, standards and procedures.
Essential Job Functions:
1. All pilots are directly responsible for the safe, legal and
consistent operation of the aircraft, in accordance with all federal
regulations and Company policies, standards and procedures.
2. Pilots in command of an aircraft are directly responsible for
and are the final authority as to the safe, legal and consistent
operation of that aircraft, in accordance with all federal regulations
3. Pilots must operate, monitor, analyze and/or timely and
appropriately react to all aircraft operational functions such as
aircraft performance, internal and external communications, air
traffic and climate conditions.
4. Pilots must perform flight operations tasks including aircraft
takeoff, climb, cruise, descent, approach, landing, taxi-in and
parking in accordance with FAA mandated standards.
5. Pilots must maintain expert knowledge of assigned aircraft
equipment type and current operational procedures.
6. Pilots must economically coordinate tasks to permit a
number of functions, including but not limited to, flight fueling,
loading, passenger handling, and associated duties to transport
passengers and cargo in a safe manner in accordance with
Company policies, standards and procedures and appropriate
federal regulations.
7. Pilots must timely and professionally address, as
appropriate, passengers on the aircraft and lead all crew activities
related to safety.
8. Pilots must professionally and timely coordinate with others,
both in the cockpit and in other operational departments.
9. Pilots are expected to present a professional image in all
public environments as a key representative of the Company to
both external customers and internal employees.
10. Pilots must maintain currency requirements with regard to
medical, training, and hourly flight requirements.
11. Pilots must perform other duties as assigned.
Working Conditions:
A pilot’s working environment is subject to varying climate
conditions, air turbulence, time zone changes, altitude changes,
changing locations, variable hours and working conditions, dry air,
jet fuel and exhaust fumes, and noise levels from engines and
other ground equipment. Pilots experience long periods of sitting
with exposure to bright sunlight as well as the conditions already
mentioned. The position requires physical exertion such as pulling,
pushing, kneeling, twisting, climbing, squatting, pinching, grasping,
bending, walking, and lifting of bags and equipment. The position
involves ascent and descent of jetbridge stairs and other airport
facilities. Pilots must be able to hear and comprehend both spoken
voice and radio communication with a range of minimal-to-
excessive background noise. Pilots require good hand/eye
coordination, visual acuity, color discrimination, and depth
perception to fly the aircraft, read approach plates under varying
conditions and correctly read, locate and access various switches,
valves, knobs, and other aircraft controls. Pilots must be able to
perform duties in an environment with potentially lowered oxygen
pressure.
Job Requirements:
Compass pilots must have a minimum of 1500 hours of total flight
time
500 hours of multi-engine fixed wing time.
Applicants must possess a Federal Communication Commission
restricted Radio Telephone Operator permit.
A Federal Aviation Administration (FAA) Multi-engine (ME) Airline
Transport Pilot (ATP) Certificate is preferred.
Applicants must have a valid first class medical certificate obtained
within the six months prior to application.
Minimum education requirement is a high school diploma or
equivalent, but a college degree is preferred.
Applicants must have a valid passport.
Applicants must be 23 years of age or older
Legally authorized to work in the U.S.
Must be able to read, speak and write fluently in the English
Language
Comfortable and effective with public speaking
Must have a High School diploma or equivalent, Bachelor's Degree
preferred.
Must have all hourly requirements set forth by FAR Part 61 to hold
an ATP Cerftificate.
Applicants must maintain a high level of alertness during regular
and emergency aircraft operations. They must have the ability to
communicate clearly and effectively in English, both in writing and
verbally, under all circumstances. Applicants must read and
comprehend written instructions and procedures and understand
verbal instructions. They must have excellent judgment,
interpersonal, organizational, and leadership skills and the ability
and inclination to solve problems. Applicants must have a highly
approachable demeanor and be comfortable with public speaking
and addressing large groups of people. They must possess basic
computer skills. They must be willing to work long hours including
evenings, weekends, holidays, and extended hours away from
home and be able to work on an on-call basis with little notice.
Applicants also must be able to travel freely in and out of all
locations served by Compass Airlines without restriction.
This position is a Federal Aviation Administration Covered position,
which is subject to mandated alcohol and drug testing. Federal
regulations require applicants to submit fingerprints for a criminal
history investigation. Applicants must pass a pre-employment drug
test, background check, PRIA records check and medical
review.
Compass Airlines is an equal opportunity employer and does not
discriminate in hiring on the basis of race, religion, color, disabled
or veteran status, national origin, gender, age, citizenship status or
other protected class status covered by federal, state or local law.
Web:
https://tbe.taleo.net/NA3/ats/careers/requisition.jsp?org=CO
MPASSAIRLINE&cws=1&rid=11
Job Code: 11
# of openings: 1
Description
PILOT
Job Objective:
related to safety.
Working Conditions:
pressure.
Job Requirements:
time
Language
preferred.
review.
Web:
