What guarantees you terrain clearance here? Tower has no ability to do that.
Good point. If you switched to departure, and departure says "cleared direct XYZ" and you are only at 2000ft, would you assume departure is ensuring terrain clearance?
Can a tower operator ever ensure your terrrain clearance?
That also needs to be treated with caution. Not all tower controllers and/or departure controls are *capable* of ensuring terrain clearance for you. If there's a DVA around the airport, fine and dandy, but there aren't many of those and no one tells pilots where they are.
A good example of all this is taking off from Bozeman, MT headed south to SLC. There's a funky bow-tie DP that sends you out one radial up 4000 feet or so, then back to the VOR on the airport before turning south.
Center radar doesn't pick you up till around 11,000'. You'll be "cleared as filed" which is direct south on the airway. Tower gets a release from center, and clears you for takeoff with no turn instructions. What do you do?
