FL350
If you have the tool to use you should use it, especially in the critical time of landing. If you're worried about the marginal cost differences of reverse thrust vs braking then someone probably shouldn't own that airplane. On the jet engine reverse thrust is usually operated by bleed air and their for takes longer to deploy at low engine RPM; all the more reason to select reverse thrust as soon as operationally allowed and use it as long as operationally allowed to. Also reverse thrust should not be quickly reduced from max to min and idle, as you can get a small burst of forward thrust if the engine is not given time to decelerate. Use them until you are satisfied your landing roll will end on the pavement.
