triple7
If nothing else,this illustrates why we need to be paid more. I knew the ca, FA, and I believe the fo was very new. Engine failure on final and cockpit/cabin filled with smoke so thick they couldn't see out the window. From my understanding they landed using ra call outs by the fo... I'm very impressed.
By Simon Hradecky, created Tuesday, Apr 3rd 2012 21:05Z, last updated Tuesday, Apr 3rd 2012 21:05Z
An Expressjet Embraer ERJ-145 on behalf of United, registration N15973 performing flight EV-5912/UA-5912 from Peoria,IL to Denver,CO (USA) with 22 people on board, was cleared to land on runway 34R. Tower controller was issuing instructions to other aircraft when he interrupted in surprise at 08:33L (14:33Z) and exclaimed "he hit the lights" followed by "runway 34R is closed" instructing the next arriving aircraft to cancel approach clearance, maintain 9000 feet and continue on the localizer, all airport frequencies began to report an ongoing emergency on the airport, traffic on runway 34L and departures on runway 25 were also temporarily halted. The Embraer rolled out and stopped on the runway remaining there disabled, tower advised emergency services were deploying. The crew of another aircraft advised they were observing the landing and they had the impression the Embraer had hit the approach lights then touched down really hard but when they taxied closer to have a look onto the aircraft it didn't appear they would have struck the lights but they aren't sure, tower commented in response they'll have the approach and runway lights inspected. The Embraer was evacuated due to smoke on board.
The airport reported the crew reported smoke in the cockpit, the aircraft was evacuated. One passenger was taken to a hospital, the extent of injuries was not known. The aircraft remained disabled on the runway, the runway was closed for 2.5 hours.
The airline reported the aircraft was evacuated onto the runway because of smoke on the aircraft.
http://flightaware.com/live/flight/ASQ5912/history/20120403/1230Z/KPIA/KDEN
Metars:
KDEN 031553Z 33014KT 3/4SM R35L/3500V5000FT -SN BR BKN005 OVC017 00/M02 A3019 RMK AO2 SLP229 P0004 T00001017
KDEN 031453Z 32013KT 1/2SM R35L/3500V4500FT -SN FG BKN003 OVC013 00/M01 A3018 RMK AO2 TWR VIS 3/4 SLP224 P0004 60013 T00001011 51015
KDEN 031440Z 32011KT 1/2SM R35L/3500V4500FT -SN FG SCT003 BKN011 OVC028 00/M01 A3018 RMK AO2 TWR VIS 3/4 P0004
KDEN 031422Z 33012KT 1/2SM R35L/3000V3500FT SN FZFG SCT003 OVC009 M01/M02 A3017RMK AO2 TWR VIS 3/4 P0002
KDEN 031404Z 34013KT 1/2SM R35L/3000V4500FT -SN FZFG SCT005 OVC013 M01/M02 A3016 RMK AO2 TWR VIS 3/4 P0001
KDEN 031353Z 35013KT 3/4SM R35L/4000V5500FT -SN BR SCT005 OVC015 M01/M02 A3016 RMK AO2 SLP217 P0006 T10061017
KDEN 031449Z 31013KT 3/4SM R35L/4000V5000FT -SN BR BKN003 OVC013 00/M01 A3018 RMK AO2 P0004
KDEN 031322Z 35011KT 1 1/4SM R35L/5500VP6000FT -SN BR BKN005 OVC013 M01/M02 A3014 RMK AO2 P0003
KDEN 031305Z 35013KT 2SM -SN BR OVC007 M01/M02 A3013 RMK AO2 P0001
KDEN 031253Z 36012KT 1 1/4SM R35L/6000VP6000FT -SN BR OVC005 M01/M02 A3013 RMK AO2 SLP206 P0003 T10061017
KDEN 031246Z 36013KT 3/4SM R35L/4500VP6000FT -SN BR OVC005 M01/M02 A3012 RMK AO2 P0003
KDEN 031232Z 36016KT 3/4SM R35L/3500V4500FT -SN BR BKN003 OVC008 M01/M02 A3011 RMK AO2 P0002
KDEN 031209Z 01014G21KT 1 1/4SM R35L/6000VP6000FT -SN BR OVC003 M01/M02 A3010 RMK AO2 P0001
KDEN 031153Z 35015KT 3/4SM R35L/5000VP6000FT -SN BR BKN003 OVC008 00/M01 A3009 RMK AO2 PK WND 36027/1110 SLP190 P0003 60011 70013 T00001011 10017 20000 55015
Reader Comments:
Weather
By Erik on Wednesday, Apr 4th 2012 14:48Z
The weather was crappy! Low ceilings and it was a mix of snow and freezing drizzle.
Weather at the time....
By Brian on Wednesday, Apr 4th 2012 04:47Z
According to ADDS, the metars at 1422Z (8:22 MT) and 1440Z (8:40 MT) are as follows:
KDEN 031422Z 33012KT 1/2SM R35L/3000V3500FT SN FZFG SCT003 OVC009 M01/M02 A3017 RMK AO2 TWR VIS 3/4 P0002
According to the last radar hit was at 8:31am at 6000' (approx 500-600 agl).
Not a nice morning.
weather?
By Steve on Wednesday, Apr 4th 2012 03:00Z
Anyone know what the weather was at time?
Active Fire
By Erik on Wednesday, Apr 4th 2012 02:56Z
While listening to the emergency operations during the Alert, a firefighter made reference to an active fire in the cockpit, and deployed an agent to stop the fire. The firefighter then reported back to command that the Halon extinguished the fire. Then advised command of only seeing hot spots behind an electrical panel.
The captain also mentioned to the fire chief that he activated the fire suppression system in the rear cargo pit. Another ARFF crew checked the rear pit, but only reported a haze from the Halon.
By Paulo on Wednesday, Apr 4th 2012 00:34Z
Either way, MSA 360º around the airport is 9200'. 9000' isn't "a tad too high"
By Paulo on Wednesday, Apr 4th 2012 00:31Z
(continued)
MSL 5351 (darn keyboard)
By Paulo on Wednesday, Apr 4th 2012 00:30Z
According to the charts (KDEN, ILS RWY 34R (Cat II or even CAT III), you should be at 10.000ft over BOOBU then descent to 9000' to be leveled at BENGL and then maintain 9000' till RLESS (about 4.7nm), following the G/S from there until you land at KDEN, MSL.
Mile High City
By (anonymous) on Tuesday, Apr 3rd 2012 21:48Z
Denver is 5400 ft MSL.
By John Doe on Tuesday, Apr 3rd 2012 21:37Z
When referring to the 'next arriving aircraft', had the aircraft already intercepted the localiser at 9,000 feet (AAL presumably)? Surely that's a tad too high?
Add your comment: (max 1024 characters)
Your IP address 174.232.132.65 is being tracked. We reserve the right to remove any comment
for any reason. Profanities, personal attacks (against any physical or legal person),
false statements or similiar as well as copyrighted materials from third parties will not
be tolerated, those messages will summarily be deleted. Links and mail addresses are
not permitted and will not appear in the display, posts trying to circumvent the
restriction of links/mail addresses will be removed. We ask for your valid e-mail address
in the email field. This address is only used by us to establish contact with you in case
of further questions, it will not be displayed anywhere or be used otherwise.
Metars:
Reader Comments:
Weather
Not a nice morning.
weather?
Active Fire
(continued)
Mile High City
