wing overheat
triple7
What exactly is a wing overheat? skywest chris or any of you other rj drivers might be able to explaing what happened here....
IDENTIFICATION
Regis#: 982SW Make/Model: CRJ2 Description: CANADAIR CRJ-200, RJ-200 REGIONAL JET
Date: 10/13/2004 Time: 0237
Event Type: Accident Highest Injury: None Mid Air: N Missing: N
Damage: Substantial
LOCATION
City: DENVER State: CO Country: US
DESCRIPTION
SKYWEST 6715, N982SW, A BOMBARDIER CL-600-2B19 ACFT, REPORTED A WING
OVERHEAT AND RETURNED TO THE AIRPORT, INSPECTION REVEALED SUBSTANTIAL
DAMAGE TO THE LEADING EDGE OF THE RIGHT WING CAUSED BY POSSIBLE COLLISION
WITH A DEER ON DEPARTURE FROM RUNWAY 34L, NO INJURIES, DENVER, CO
INJURY DATA Total Fatal: 0
# Crew: 0 Fat: 0 Ser: 0 Min: 0 Unk: Y
# Pass: 0 Fat: 0 Ser: 0 Min: 0 Unk: Y
# Grnd: Fat: 0 Ser: 0 Min: 0 Unk:
WEATHER: NOT REPORTED
OTHER DATA
Activity: Business Phase: Take-off Operation: Air Taxi (Commuter)
Departed: DENVER, CO Dep Date: Dep. Time:
Destination: MISSOULA, MT Flt Plan: UNK Wx Briefing: U
Last Radio Cont: UNK
Last Clearance: UNK
FAA FSDO: DENVER, CO (NM03) Entry date: 10/14/2004
In the CRJ - pretty much every airline jet except the DO-JET(what's up with the boots???) - the wing leading edges are heated with engine bleed air for anti-ice purposes. There are a number of problems that can occur that can cause too much bleed air to go to the wing which causes the 'wing overheat' and of course if the leading edge gets too hot that can cause damage.
Jason
"Wing Overheat" is a warning message and audible warning generated by the aircraft EICAS. The leading edges of the wings are heated by perforated tubes just underneath the aircraft skin, fed by 14th stage bleed air from the engines (=HOT) for anti-ice. That message is triggered when a sensor detects an overheat in one of those anti-ice bleed ducts.
If the aircraft wing struck an object on takeoff that air duct could be damaged, leak,and trigger the overheat warning.
Good to know you are learning something in that sim back there
. I've always wondered about why the DoJet had boots? Something to do with the high wing? I would think ice could still break off and fall into the intake.
Ethan
How?
Yeah - the DO JET engines sit in front of the wing - not much chance of the ice blowing forward when you pop the boots.
Jason
Unless that Citation goes whizzing past you at cruise altitude.
D'oh! Double kill! Killing spree!
Sorry, still hyped up at playing Medal of Honor: Allied Assault online with the JC crew.
It was my understanding that the Do Jet had much in common with the turboprop version. Many turboprops do not have enough bleed air to run a hot wing and have boots. If they basically used the same wing and systems as the turboprop, this could explain the boots.
