Why a 3-bladed prop?
killbilly
Elementary question to many of you, I'm sure.
What's the advantage of having a 3-bladed prop vs. a 2-bladed on a piston single?
ppragman
FLIPY FLAPS!
Its quiter, and has more drag, so you can slow down a little faster. Though it doesn't seem to have the get up and go that a 2 bladed prop has.
killbilly
Is that the only reason?
You see 3-bladed props on the higher performance singles. Cirrus, Cessna's larger ones (182, 210, 400), Mooneys...
I'd heard they were quieter, and I'm curious about why that is, as well.
tgrayson
People buy three-bladed props because they tend to improve takeoff and climb performance. Cruise sometimes suffers. They're quieter due to reduced tip velocities. A shorter blade moving at 2700 RPM won't be moving as fast as a longer blade at the same speed.
And, almost everyone agrees, three-bladed props look cooler.
ppragman
FLIPY FLAPS!
Big time, in Inland's 207s it was about 7-10kts.
As for takeoff performance, I've heard mixed reviews, I've heard somepeople say that the extra drag of the third blade slows your acceleration slightly and leaves you in the same boat you were in before, however climb performance once you've left the ground is definitely better.
They do look much cooler compare this:
with this:
CFIT99
I'm probably commenting ironically...
ALTHOUGH...single blade props are the most effecient design...but are there any?
beechpilot84
On a Piper Arrow it eliminates the restrictions on the RPM. With a two-bladed prop there is a limit on continuous operation within a certain RPM band, I forgot what it was but it's like 2200 to 2400 or something like that. At least on the 1970's models I was flying.
deadstick
Agreed.
The PA46 originally had a 2-bladed prop. I think the scimitar design, when compared to the straight 3-bladed models, has reduced the noise, some drag, etc so that the pro/con gap between the 2- and 3-bladed props has been narrowed.
...and the 3-bladed scimitar looks WAY cooler.:bandit:
Maurus
The Great Gazoo
The three bladed prop in on the DA40-XL is one reason why the cruise increases from a CS model. Not to mention it is wood/composite compared to metal.
///AMG
Interesting, I remember having the same restriction on 3-bladed Arrows I have flown. Maybe someone just hadn't gotten the memo where I was flying or something :)
Minuteman
“Dongola”
I just figured more blades was the best way to transmit more power when you have a restriction on the blade length and, to a lesser degree, the range of RPMs (torque-y versus spinny ... what kind of RPMs did the Thielerts turn?).
But am I understanding correctly there is sometimes a choice of two or three-bladed props for the same size engine?
Blackhawk
Yes. Sometimes it is an STC, sometimes it is part of the type certificate data sheet.
Blackhawk
You may need to look at the STC or the type data sheet for the new limits. On my 8KCAB the RPM indicator still has the old limits marked on it, but the type data sheet removes the intermediate RPM limit and increases the maximum RPM.
I've seen the same thing with other airplanes... for example with some 172s Vfe 10 degrees is 110 knots, yet many pilots assume the limit is 95 knots.
