popaviator
I'm curious about what others think of the MAP for this approach. Where would you hold?
http://204.108.4.16/d-tpp/1007/05320LDA19R.PDF
Good question, I'd obviously fly to the Concord VOR...but there's no hold pattern depicted.
Given no other choice, I'd hold inbound on the VOR parallel with the ILS inbound course.
I know I have protection on the ILS approach path, and if I'm having to hold somewhere like that...that's where I want to be.
I would ask ATC upon going missed.
Well, I wouldn't really worry about where I'd be holding because the last time I was given the published missed without specifically asking for it was never.
You will not hold unless issued holding instructions by ATC.
From the Instrument Procedures Handbook:
The missed approach course begins at the MAP and continues until the aircraft has reached the designated fix and a holding pattern has been entered, unless there is no holding pattern published for the missed approach. It is common at large airports with high traffic volume to not have a holding pattern depicted at the designated fix. In these circumstances, the departure controller will issue further instructions before the aircraft reaches the final fix of the missed approach course. (p. 5-33)
In a lost comms situation, we might assume that the VOR is our new clearance limit and proceed accordingly, either executing another approach or diverting to the alternate.
:yeahthat: there is no hold in this approach. not sure why you felt you needed one? not all missed approaches require a hold.You will not hold unless issued holding instructions by ATC.
You'd go missed? Mins are for wusses!:bandit:
Edit: I'd go missed, left tuen direct to the VOR and hold N/W of the VOR, R/turns.
