The suffix nimbus just means rain, the taller the cumulus, the higher the updrafts are reaching, meaning a more powerful downdraft. Turbulence is something else entirely.
Meaning since the cumulus is higher in a towering cumulus, then turbulence is greater. bah. I got it wrong.![]()
Another question that I struggled with. Is high pressure associated with what type of weather. I thought it was usually good weather but not always.
cumulus is just a type of cloud, towering or not they are the same type of cloud. To create a "towering cumulus" there myst be a lifting force, i.e convection. As that cloud climbs higher and higer the lifting force becomes weaker and eventually that rising air must fall, creating a downdraft. The higher it went, the further it will fall, generating a greater force.
Turbulence is something different entirely, turb is unstable air caused by the uneven heating of the earth surface and other factors. Turb is associated with convective activity, but I would not consider a downdraft to be turb, it is much worse.
That is kind of a bogus question, because they are the same type of cloud, one just has a lifting force associated. If those were the only two then definately go with the towering cumulonimbus, the taller they are the stronger they are. Both are a hazard to be avoided by aircraft, but the towering variety definately are the greater hazard.
Did your teacher write these questions or are they from a manual or book?Thanks. My ground school teacher loves confusing questions.
Definately violent beats "very strong" Quote it if you want, it is from the FAA.
You are correct, I had an instructor that always called them "Towering Cumulonimbus", that is still screwing with me.CB's are the strongest of any cumulus clouds. . .
/weather guy departing right now.
AAAH!! Wrong. There is no such thing as a Towering Cumulonimbus. There is Towering Cumulus, and Cumulonimbus. End.
There are 27 states of the sky. L2 (Towering Cumulus) is far less violant than L3 or L9 (CB or CB with Anvil or Mamatus observed). L standing for Low etage.
Both of these clouds are convective in nature, but it is important to realize and understand that a Towering CU does not have LTG or Hail associated with it, where as a CB does. So no. . . the "towering" variety is not the greater hazard. Yes they are both Towering cumulus cloud types, but a TCU is the second stage of a mature thunderstorm or CB. First stage is the cumulus stage, then towering cu, then CB. CB > TCU. The End.
If I really have to break it down further, I'll shoot myself.
/weather man out for good.
