In my Tracon, if you were on a flight plan we still have all your normal info (callsign, altitude, ground speed) and a red RF on top. If you were originally squawking 1200 we'll see your target and a limited data block with your altitude and ground speed with the red RF. (Altitude assuming you have mode c). 7600 is radio failure, not transponder failure so all the normal info broadcast by your transponder is still there. If your transponder failed obviously we won't know you're squawking 7600.
