SpiceWeasel
Tre Kronor
Why did I miss this? Is there already a thread about this?
:crazy:NTSB IdentificationDFW08CA215
Scheduled 14 CFR Part 121 Air Carrier operation of TRANS STATE AIRLINES (D.B.A. American Connection)
Aircraft EMBRAER EMB-145LR (N814HK)
Injuries 36 Uninjured.
Accident occurred Thursday, August 14, 2008 in St. Louis, MO
While en route to the destination airport, the first officer (FO) warns that his flaps 45 degrees landings are “a little extreme.” The FO continues by stating that the landings are “a little non-standard, but it’s way more fun.” The flight data recorder (FDR) showed an increased in the airplane’s pitch angle at approximately 34 feet above ground level. The landing flare continues to increase to approximately 13 degrees of pitch angle with a corresponding angle of attack of 17 degrees. The airplane’s stick shaker/stall warning system activates seconds prior to the airplane’s landings. During the landing sequence, the airplane’s tail sections contacted the runway.
