kfischer11
What causes VOR rodor modulation error? I know it has to due with specific prop settings but what exactly is affecting the signal from the VOR?
The VOR signal is modulated 2 ways (FM and AM) at 30 Hz (1800 cycles per minute). Therefore, if you're running 1800 RPM and the signal is coming from in front of you (through the prop) that can throw off the signal (probably the AM portion of it, I would imagine the FM portion is relatively unaffected) resulting in wild CDI swings.
