Vmc Demo in Seminole
bap327
Any helpful hints on getting through this? I have my MSEL on Sat and this is the only thing that I am struggling with.
Thanks in andvance for any help.
Well, what exactly is the problem? I'd be happy to lend some of my MEI knowledge to helping out if I can. Are you struggling with the entry or recovery? Send me a PM.
Jay
I'd be glad to read the other people's help. I'm studying up on Vmc in the Seneca, so it should be fairly similar.
I guess the big problem is the initial entry...heading altitude and then on the recovery maintaining the heading? I guess it is a feel that will come with time but it is killing me now.
Just a question, since it's been about a year since I did stalls in a multi. Do you guys do slow flight and power off stalls below VMC? Or do you recover from the imminent stall before going before redline? I want to say I did slow flight and stalls below VMC for my checkride, but can't remember.
Take down to redline, then below if you can. At first sign of a stall or going over like a barrel, recover. Density alt in Florida kinda screws up our Vmc demos.
Wow! You stall the airplane while doing a Vmc demo? I would like to observe that (from the ground).
Hahahaha...you make me laugh. Density altitude here was something like 8000 today. On the ground.
I do remember what we did on VMC demos.....
1. pulled power to 12" on the left engine, full power on right engine, maintaining level flight if able.
2. Established a pitch attitude that resulted in a 1 mph per second decrease in airspeed.
2. Limited rudder input 10 mph above red line.
3. Initiated recovery at first sign of loss of directional control or stall.
4. simultaneously reduced power to idle on the operating engine and pitched down slightly.
5. Once at blue line, added power to the operating engine to maintain level flight and airspeed at blue line.
On my checkride, the examiner seemed preturbed that I limited rudder input 10 mph above stall, but most other MEI's I've talked to agree that it's best to limit rudder input at 10mph/knots above VMC, especially in a situation where density altitude is high.
With the exception of number 2 (I was STANDING on that sumbeotch!), that's pretty much how we did them in the Travel Air which HAS a critical engine. (correct me if I'm wrong, but the Seminole is a recip, right?... i.e., no critical engine?).
It's a pretty straight-forward maneuver and one that SHOULD go smoothly and quickly if learned right.
Keeping your heading should be THE main point of the entire maneuver as Vmc is the loss of directional control.
In short, fly the airplane as you would for an engine-out demo as that is basically all the maneuver is with the exception that you are adding a higher angle of attack into the mix......, and at the FIRST sign of loss of directional control or stall (buffeting, stall horn), do as #4 & #5 above.
Keep an eye on your heading and just fly the plane, don't let it fly you. (okay - sorry about the cliche.
Best of luck!!
R2F
The Travel Air is a recip too.
I think you meant to say that the Seminole has counter-rotating props (meaning it does not have a critical engine per se)...where the Travel Air does not.
[With the exception of number 2 (I was STANDING on that sumbeotch!), that's pretty much how we did them in the Travel Air which HAS a critical engine. (correct me if I'm wrong, but the Seminole is a recip, right?... i.e., no critical engine?).]
This is a falsehood ( IMO ) in Multi training ie: an airplane with counter rotating props ( which is what I assume you meant concerning the Seminole ), has no critical enging. What does the term Critical Engine mean?
[It's a pretty straight-forward maneuver and one that SHOULD go smoothly and quickly if learned right.]
Word of CAUTION ... don't rush the Vmc maneuver. As stated the degradation of airpseed should be at the rate of one knot per second. This demonstrates Static Vmc, if you rush it you may see Dynamic Vmc ... which is a lot worse and possibly non recoverable.
[Keeping your heading should be THE main point of the entire maneuver as Vmc is the loss of directional control.]
At what point does one initiate a recovery ... 5 degrees of heading loss , 10 degrees of heading loss, 20 degrees ... ? Personally as soon as heading control is lost demo is over ... with the qualified statement that any stall indication is an IMMEDIATE recovery.
[In short, fly the airplane as you would for an engine-out demo as that is basically all the maneuver is with the exception that you are adding a higher angle of attack into the mix......, and at the FIRST sign of loss of directional control or stall (buffeting, stall horn), do as #4 & #5 above.]
Airspeed is Life ... Airspeed is Life ... Airspeed is LIfe
[Keep an eye on your heading and just fly the plane, don't let it fly you. (okay - sorry about the cliche.
Have a plan that will work and work your plan
Best of luck!!
R2F
Yeah, the airplane normally stalls BEFORE you hit Vmc, therefore the demo never really gets there. Stalling while doing Vmc is just crazy. That's why we end the manuever at the first sign of the stall instead of pushing it.
Since no one has anwered this question yet, I'll be happy to. Stalls and slow flight are typically done below red line. This is safe because neither engine is producing enough power to really cause a problem, and both engines are turning. Chances are, even in a power on stall, that if you lost an engine during the manuever, you would quit the manuever before actually stalling the airplane. I don't know of anyone who practices stalls single-engine (probably because anyone who did would be pushing up daisies by now). It isn't likely that you'll encounter an imminent stall above red line unless you're flying in some interesting flight attitudes.
Jay
Hmm, maybe I've got it backwards. Maybe it's Vmc that occurs before stall. I know we were talking about one occurs before the other in Florida, and this was on the ground before we got in the plane. Nevermind, I've only got 0.7 MEL, so I really don't have a clue yet anyway.
In the seminole, Vso is 55 and VMC is 56. Usually you will stall the plane first during th VMC demo if you don't restrict rudder or aileron movment.
The seminole is a great airplane. I have had it well below Vmc still flying beautifully.
If you use full rudder in the Seminole in Florida you will 99.9% of the time get the stall warning horn first....hen just smoothly recover.
