Vle vs. Vlo
FlyboyZR1
If an airplane has a Vle speed of 150mph, and a Vlo of 125mph, can the landing gear be extended above 125mph?
I always thought the gear could be extended below Vle, and that it can only be retracted below Vlo ... but the FAA Handbook says the gear can only be extended below Vlo.
Vle is the speed at which you can fly around with the gear down and locked into place. If you took off in an aircraft with a Vle speed of 150mph, that means you could, if the gear were extended and locked into place, fly up to a speed of 150mph safely. The maximum speed that you can extend the gear from the retracted position, however, is 125mph, or Vlo. Many aircraft have Vle and Vlo the same speed... but not all. One reason why the speeds may be different are the aerodymanic principals of the gear while in transit... within the speeds of 126 up to 150, in the case of the example given, the forces placed on the gear may be too much and could cause a threat. Or maybe at that speed, the gear may not come down because of the speed. However, if the gear is already locked into place by 125mph, you can safely reach a speed of 150 without having gear doors fly off, or worse.
MOst airplanes have a Vlo speed to keep the nose gear from slaming back into the gearwell too quickly. (most light airplanes)
However some others have gear doors or other pieces that move durring gear extension or retraction that can't handle the stress of a higher airspeed. (the B-707 comes to mind)
So Vlo applies for both extension and retraction.
Then you can speed up to Vle.
Hmmm, Seneca huh?
Think about the nosewheel and which direction it retracts. It would have to retract against the relative wind, and it's only safe to do so below 125 mph.
Hmmm, Seneca huh?
Close ... it's an Arrow II.
Not only that, but gravity too. Gear doors are usually a limiting factor for speed, but gravity and wind can put too much strain on the torque tube or chain for the system to safely handle.
-mox
It has to do with the motor moving the gear, the aerodynamic forces working against the motor is the reason for the limit. Most gears can take the stress but to keep weight down and motors small you have to limit the stress on that motor or you'd burn it up.
Jim
I *think* in the Arrow II you can RETRACT the gear up to 125, but you can EXTEND it at 150 mph or less. But it's been a while.
