89-LX
So I had a good conversation with a line check airman regarding being cleared for the visual approach to a runway with an offset localizer. We got on the conversation talking about the opening of runway 18R/28L in ORD. We got a tech ops bulletin that stated the following:
We also spoke about DTW and when the ATIS is broadcasting the localizer as being offset, that we must fly that in visual conditions. Here is the actual ATIS from DTW right now as the example:
Granted I'm not that knowledgeable with the handbook, but I searched JO 7110.65V and wasn't able to find anything in there. The only thing I came close to finding was approaches that have runways with spacing between 2,500 and 4,300 feet, which only states to be given a 30 degree intercept for the extended centerline of the runway.
Where we came into the conversation, was ATC phraseology. I could very well be wrong, and I'd like to learn the citation of where it is, but he said if we're cleared for the visual in DTW or ORD, it's manditory to follow the offset localizer inbound. He stated that the ATIS is controlling for DTW because it has offset frequency right in the ATIS, and for ORD we have the tech briefing that says it. I argued (not argue, but disagree) with him that if we're required to follow the offset localizer, that ATC must issue a clearance that states "cleared for the visual approach, follow the localizer inbound" or something in that nature.
If I'm wrong, I'd just like to learn where it states that in the FAA handbook or regulations. On the other hand, if I'm right, I'd still like to see a source if I could as a rebuttle to the regulations.
Even in visual conditions and with visual clearances, it is imperative 10R arrivals follow the LOC course. If crews attempt to align for the straight in early, it will appear that the flight is going to violate the NTZ and cause ATC to issue “Miss” instructions to 10R and/or 10C traffic.
DTW ATIS INFO F 1253Z. 36003KT 10SM FEW140 SCT250 06/03 A3045 (THREE ZERO FOUR
FIVE). SIMUL VISUAL APCH IN USE RY 22L, RY 22R USE Y LOC FREQ 111.75. DEPG RWY
21R, RWY 22L . NOTAMS... RWY 21L, 3R CLSD, RWY 27L, 9R CLSD, RWY 27R, 9L CLSD.
NMRS TWYS CLSD MKD BY CONES AND FLASHERS. RUNWAY 22R YANKEE LOCALIZER IS
OFFSET. PILOTS ARE REQSTD TO OPER THEIR TRANSPNDR WITH MODE C ON ALL, TWYS AND
RWYS, ALL ACFT READBACK ALL ASSIGNED ALTS. ...ADVS YOU HAVE INFO F.
