Victor airway question
centralhome
If you look at V56 going to the MCN vor, it says the R-265 is unusable and GNSS is required. Does this mean you can't use the vor to navigate from PRATZ to MCN on V56? If GNSS is required shouldn't it be a T route(RNAV route)?
Thanks
Sorry did not post a picture of it, but I figured someone can use Foreflight to look it up.
I dont know, but it's interesting. Here's the chart in question.
My guess is it that for some reason that radial from the VOR is unusable (maintenance needed, obstructions blocking signal, or something of the sort). Because that airway was at one time usable, it is still being published, but you need a GPS to navigate because the VOR signal is unreliable. It may be theoretically possible that the issue will be fixed (don't count on it), so they continue to publish the airway for if/when that time comes.
Same thing going on with the VOR by me (AUW if you want to look it up) only its worse. Nothing is usable beyond 10 miles, so every airway has a similar warning.
Thanks for the answers. I thought if it was temporary there would be a Notam on it. But I guess since it is published on the chart, no need for a Notam.
Some Remarks from Airnav
MCN
MACON VORTAC
MACON, GA
Location
Lat/Long: 32-41-28.259N / 083-38-49.859W (32.6911831/-83.6471831)
Elevation: 381.0 ft.
Variation: 01E (1965)
Operational Characteristics
Type: VORTAC
Class: H-VORTAC
Frequency: 114.20
TACAN channel: 089X
Altitude code: H (high)
Hours of operation: 24
Voice ID: no
Morse ID: -- -.-. -.
Station call name: MACON RADIO
NOTAM facility: MCN
FSS:
FSS hours of operation: 24
Technical Characteristics
Accuracy: NOS
Monitoring: Internal monitoring plus status indicator
at control point
Owner: FEDERAL AVIATION ADMIN
Operator: FEDERAL AVIATION ADMIN
Common system usage: yes
For public use: yes
Remarks
  1. 3RD PARY SURVEY; 11 NOV 2008.
  2. VOR PORTION UNUSBL 085-099.
  3. VOR UNUSBL 240-280 ALL DISTANCES ALL ALTS.
  4. TACAN PORTION UNUSBL 240-280 ALL DISTANCES BLO 3000 FT.
It probably started out as a NOTAM, but I'm guessing it's been that way for quite a while, so they decided to just put it on the chart.
Also leads me to believe it won't be fixed anytime soon. NextGen GPS only blah blah blah...
Because that airway was at one time usable, it is still being published [. . .]. It may be theoretically possible that the issue will be fixed (don't count on it), so they continue to publish the airway for if/when that time comes.
Also, because it is an airway, certain features of an airway, such as the MEA, still apply. (Without the airway MEA, grid altitudes would take effect for flight planning---which is not a significant factor around MCN but could be in mountainous areas.)
