Trying to figure out how to log the time.
2.4 hours total time in flight. Between the 1.2 and 2.0 timeperiod, minimums were 1400 feet with tops at 3500, so I went higher to avoid the clouds.
How do I log the time? on top? What about the time I transitioned to higher?
What does that mean? If you are operating under ifr, you maintain radio communication throughout and if you are operating vfr you don't need to talk to anyone unless you are in airspace that requires communication.If you couldn't see the ground below (or see it somewhere in your slight) you need to be in communication with someone.
Exactly what are you asking? I'm not aware of any "on top" categories in FAR 61.51 or columns for it in a logbook.
If you're talking about logging "actual instrument" time, as others point out, that reserved exclusively for times that you were in conditions where you needed to rely on the instruments in order to maintain control of the aircarft - to keep the shiny side up.
complex?
What does that mean? If you are operating under ifr, you maintain radio communication throughout and if you are operating vfr you don't need to talk to anyone unless you are in airspace that requires communication.![]()
Well, if one is familiar with the Gulf Coast area, clouds tend to roll in between LCH and EFD which is what I was flying. Between ORG and T00, at 1815, I was unable to flying in the clouds and the fire haze, so I climbed to 4500 to clear the clouds. I was "flight following" with Beaumont TRSA, so they gave me permission to climb. I logged the actual time transitioning up through the clouds. By then, it was dark and I was flying with the glow from the lights of the city underneath the clouds until I left area where the clouds had formed. I made a comment in the comments portion, but I wasn't certain. Hence, my reason to ask.
You can log the time spent flying solely by reference to instruments due to meteorological phenomenon as actual instrument time. Time spent in VFR conditions above the clouds probably does not count as actual instrument time.
Please say you had an IFR clearance when you climbed "through" the clouds.
Uh oh.Can't say. I requested from Beaumont approach to climb higher. They said yes.
it is my understanding that this is not actually what one would call "VFR on top" as that implies an earlier IFR clearance through a BKN or OVC cloud layer flying solely by reference to instruments.
Uh oh.
If you "can't say" that you were given an IFR clearance, that means you were VFR at least initially (you also mentioned that you were "flight following" which is a VFR procedure). If you "can't say" that you requested an "IFR climb" then the chances approach near certainty that you were not. "Sure, climb higher" is =not= authority to violate VFR cloud and visibility rules.
Please say your real name isn't in your profile.
Nice slippery slope. . .not. I won't go into the semantics of right/wrong, so help me, please. 'Source' the exact words of IFR climb in the FAR/AIM to perform an "IFR climb" when I'm on VFR traffic advisories. I need the insight.
- So from the above you can see two things:5-5-13. VFR-on-top a. Pilot.
1. This clearance must be requested by the pilot on an IFR flight plan, and if approved, allows the pilot the choice (subject to any ATC restrictions) to select an altitude or flight level in lieu of an assigned altitude.
NOTE-
VFR-on-top is not permitted in certain airspace areas, such as Class A airspace, certain restricted areas, etc. Consequently, IFR flights operating VFR-on-top will avoid such airspace.
[SIZE=-2]REFERENCE-
AIM, IFR Clearance VFR-on-top, Paragraph 4-4-8.
AIM, IFR Separation Standards, Paragraph 4-4-11.
AIM, Position Reporting, Paragraph 5-3-2.
AIM, Additional Reports, Paragraph 5-3-3.[/SIZE]
2. By requesting a VFR-on-top clearance, the pilot assumes the sole responsibility to be vigilant so as to see and avoid other aircraft and to:
(a) Fly at the appropriate VFR altitude as prescribed in 14 CFR Section 91.159.
(b) Comply with the VFR visibility and distance from clouds criteria in 14 CFR Section 91.155, Basic VFR weather minimums.
(c) Comply with instrument flight rules that are applicable to this flight; i.e., minimum IFR altitudes, position reporting, radio communications, course to be flown, adherence to ATC clearance, etc.
3. Should advise ATC prior to any altitude change to ensure the exchange of accurate traffic information.
im not right/wronging you personally.
but it is absolutely wrong to violate VFR cloud clearance/vis minimums if you are not SPECIFICALLY on an IFR clearance.
wrong, and DANGEROUS.
im guessing (only a guess) you are not instrument rated or this might be more clear (i am not an instructor so i dont know a great way of explaining it maybe).
My point was simply trying to identify how to log the time I flew while VFR from point A to point B, and I had to climb higher to maintain VFR around dusk. My destination was clear with 10 mile vis, no clouds; airports in between had no ATIS. Heading west, clouds at 2500 made it unwise for me to maintain that altitude. I simply wished to insure the .2 actual was okay as I climbed to maintain VFR ABOVE the clouds.
An IFR clearance is not necessarily required to log actual IFR.You just log it normally. You weren't in actual. If you didn't get an IFR clearance you better have not logged any actual.
