Counterclockwise from the pilot's point of view? I was under the impression that was bad for it.
You should go learn how an internal combustion engine works.Counterclockwise from the pilot's point of view? I was under the impression that was bad for it.
ananoman said:The only problem with that method is that the distance you move the prop has nothing to do with the likelyhood of the engine starting. If you move it in the direction of normal rotation, you increase the risk that it will start. In the left magneto there is an impulse coupling that engages at low rpm. The impulse coupling is spring loaded and 'catches' as the engine rotates. It then springs forward, accelerating the magneto. By doing this it retards the timing and generates a hotter spark than would otherwise be possible at low rpm, increasing the chances of a start. If you turn the engine you will hear the impulse coupling 'click' as it releases. At higher rpm when the engine is running it disengages.
If you turn the engine the wrong way, the impulse coupling will not engage, making an accidental start unlikely.
It could only do that if there is fuel as well. And since we don't shut our engines down by cutting the ignition........ there shouldn't be enough.Why would it be bad? When you're dealing with an engine that's basically 1940s-60s technology, what component would you actually be hurting?
I found this thread from 2003:
http://forums.jetcareers.com/threads/which-way-to-turn-a-prop.5858/
The only issue brought up there is the potential for premature wear on dry-vacuum pumps... but to be honest dry vacuum pumps are such pieces anyway that I think that's a bogus argument (and that's essentially what the old thread concluded as well - the attachment that gears the pump into the engine is purposely made of plastic, so that when the pump inevitably seizes up the plastic attachment rod just shears off to prevent engine damage/stoppage). In other words - it's attached to the engine with plastic... it has bigger problems than turning backwards.
However, this guy articulated exactly why I turn the prop backwards:
In the event that my magneto ground/P-leads are eff'ed, I don't like the idea of increasing the likelihood of an inadvertent engine start by allowing the impulse coupling to wind up and spring the prop forward.
I would be more comfortable turning the prop by hand.Does it cause any harm to click the starter for a second or two to move the prop out of the way of where you need to hook up the towbar on a Warrior or 172? I'm not crazy about moving the thing by hand, but I don't want to burn up a starter or worse.
Certain vacuum pumps have the vanes angled in the pump body, theoretically turning one of those backward could jam it up and break a vane.Some people say it can damage the vacuum pump(s). It won't hurt the engine itself.
I'm with everyone else though. Move it slowly and don't force it past a compression stroke and you'll be perfectly safe.
My objection to bumping the motor with the starter is much more of a safety one than a wear one. A little bump to put the blades where you want them is not an appreciable amount of wear on the starter. However...No, it's not bad, but why put the extra ware on the starter?
I'm sure if you were paying the mx bills, you'd see it from my position, too.
You'd think so, but in the engines I have the most experience with, if you, say, replace a starter and then crank it in the shop even with the mixture ICO, after shutting off the engine with the mixture, the engine will try to fire every time unless you have a setup that allows you to shut off the mags while cranking the engine (I.e, separate magneto and starter switches). And that is the main reason I suggest not bumping the starter. Also, if you turn the prop slowly by hand, you'll be much more aware of what is in the prop arc and less likely to clonk the tug or another airplane with the blade. Obviously standard precautions apply, make sure the mags are off, do a mag ground check before you shut down, leave the airplane chocked until you're actually ready to tug it, etc.It could only do that if there is fuel as well. And since we don't shut our engines down by cutting the ignition........ there shouldn't be enough.
I gave my student that same schpiel when I taught him to hand prop our TriPacer. Darn thing fired on the first pull. Though, we have a primer system so you don't have to pull the prop through to prime.Go find a grass strip and hand prop a cub.
It will do a few things for you. It will show you what is necessary for combustion such as a spark and fuel. It will show you that you would likely need to turn the prop through a few times to prime the cylinders. Lastly, it will show you that it is relatively difficult to hand prop an airplane.
Make sure the mags are off and grab the prop and put it where you need it.
I thought I was the only one in the world who taught that...Music, Mixture, Mags, Master, Motion. I know it's taught and engrained in every student here, and I have never found the mags left on, but I won't leave that to chance...
