Using Callsigns
DeltaASA16
Hey Gang-
This might sounds rediculous.. but I am curious. Is it possible for a GA pilot to make up his own call sign and use it when he flys?
Thanks,
Adam
I don't think so. Maybe if you have an airline they will make the callsigns alike but thats it. Imagine telling atc your own custom callsigns.
Yes, there is an application process and you have to get FAA approval. Several corporate flight departments and flight schools have their own call signs. I'm not sure if you must have more than one airplane to do it, but it's possible for part 91 operators.
I believe the callsign is only valid in the local airspace-I remember some friends that go to DCA were telling me about it. In Orlando airspace, they are "Connection xxx" but out of the area, such as on a long XC, they have to revert to the standard phraseology.
Check out this website:
http://www.faa.gov/ATPubs/CNT/CNTHME.HTM
Go to section 4 and then 1-4-2
Kind of a neat site if you're bored or just want to learn something. The fun part of callsigns is getting far away from home where you have to repeat it 30 times just so the controller can figure it out!
Our callsign is "Sioux" when we are in the area of Grand Forks. When dealing with any other ATC facilities, we revert back to our N number. They had a process going to get the Sioux callsign nationwide, but i think some indians must have whined or something because it never did go through.
Not sure why they whined either. At least someone is still using their name that has nothing to do with a casino.
Back in the -10, each squadron had a list of callsigns assigned to that unit. Each flight leader "bought" his own callsign at a callsign auction (these are flight callsigns, not personal callsigns), that the squadron held every so often. So you could tell who was who based on their flight callsign on ATC freq. My original assigned was "Airwar", so each time I flew, my flight would be Airwar 1/2, or 1/2/3/4. In my new plane, we'll fly with "Ghost", "Nightmare", etc. Operationally, within a combat theatre, each squadron will be assigned their own callsign that all their planes will use, so that squadron can be identified by others....the different flights are noted by different numbers; ie- Monkeyspanker 31 flight, being different from Monkeyspanker 51 flight.
The USN and USMC do it the same way the USAF does it in combat. Each squadron has it's own callsign, and the squadron planes use that callsign along with the nose number of the particilar aircraft, ie- F-5s from VMFT-401 at Yuma MCAS use the callsign "Sniper", whereas the AV-8 Harriers from VMA-211 use the callsign "Wake". So Harrier number 05 from 211, Wake 05 flight, with #2 being "dash-2".
...with the proceeds typically going to the squadron beer fund, and the crappy callsigns saved for the flight leads too cheap to bid for one. At least, that's how it was in the good ol' days, before everybody got all PC.
Now there are squadron "family fun days", complete with Kool-Ade and trampolines for the kiddies!!!
Mine cost $71.
Not long before they closed ATA in Orlando finally got approval to be called "redtail". When I was there it just the N #
If you're IFR you can file a call sign for each flight. You don't have to use the N# - try it sometime.
I called myself "Toadsuck One" on my last trip to Arkansas.
I am sure you got a few laughs with that one.
John wasnt I right about the ATA redtail call sign. Was that only for local or all trips.
Where does it say you can do that? Make up a callsign for an IFR flight? I've never heard of being able to do that, but if you can that pretty sweet.
Yeah, because that'll change the way I do things forever!!!
Well let's just say I know the briefer pretty well
Honestly they will let you do it, but they will often ask you about the call sign, and some controllers (who have no sense of humor) will ask for your N#.
Tim - ATA had an agreement with Orlando ATCT to use Red Trainer as a call sign for all flights, not just IFR. Yes you are correct.
Wow.. thats great! I plan to file IFR down to Raleigh (RDU) sometime this summer! Now I just need to get a cool call sign!
Thanks a lot!
-Adam
Thanks a lot!
-Adam
LOL make sure it is a mean CS. Fly a 152, and file as Viper, the briefer will laugh his ass off
