You’re clearly a hack.Yeah, not like I’ve worked on GA airplanes for the last 15 years and changed more control cables than I can count.
The oldest C172 I flew was a ‘67 model and it had a hole in the yoke shaft from the factory.Do all 172s have a hole in the yoke for a control lock?
I’ve sometimes wondered if the places that use the seatbelt as a control lock (on PA28s) are doing anything concerning; sometimes I found them with notable tension on the belt.
Then why do those cables get checked for tension at every 100hr and annual?Cables in 172’s don’t “give out”. Those are steel cables with incredible strength. You don’t know what you’re talking about
I’m more worried about the compounding effects of corrosion, fatigue, wear from fairleads/stuck pulleys….For those on the sidelines who may be curious about this topic, here’s a good kitplanes article to get your feet wet.
Maintenance Matters
Most homebuilt aircraft use control cables, so it’s helpful to understand how to select, install and maintain them.www.kitplanes.com
It’s from the perspective of an experimental homebuilder who may be figuring this all out on their own design, but has some good gems in there. For example, a 1/8” stainless steel cable has a minimum breaking strength of 1760 lbs. Cable stretch (plastic deformation) is going to start below that, but still well above human capability.
…Until you take into account the fact that cable and pulley flight control systems employ mechanical advantage, and the force you apply at the yoke isn’t necessarily the force felt in the cables or at the flight controls thanks to force multiplying bellcranks, etc.![]()
That all makes sense.So here's the latest:
I flew the airplane yesterday and - per @Roger Roger 's suggestion, trimmed it out in cruise, straight and level, with the yoke deflected, and then let go to see what it would do. It flew perfectly straight and level for about 40 seconds or so, and then very, very gradually started rolling left. Just very slightly. As it rolled further left, it picked up a little more speed in the change. Again, gradual, just not AS gradual. We repeated this test a couple times just to make sure of what we were seeing.
When I got in this morning, I had a thought and pulled the usage logs on the airplane. Sure enough, it had been in for what was described to me as "extensive" maintenance about 20 hours ago. Which, looking at the usage logs, corresponds to the earliest known report of this behavior. So I took some pictures, emailed the DM.
He thinks maybe they did something at the Mx shop, said it could be deferred for a little while, and to bring it down to them and they could fix it in just a couple of hours.
So there ya go.
Who up pondering they D20...the?
Your school has a Dungeon Master?
LolzCables in 172’s don’t “give out”. Those are steel cables with incredible strength. You don’t know what you’re talking about
“The grand aircraft magi consults the scrolls before jotting <rolls dice> ‘OPS check good, aircraft RTS’ in the log book.”...the?
Director of Maintenance....the?
Me: wait killbilly is in the Klan?!But I *did* put on my robe and wizard hat before I called him.
Me: <wiped brow> ok coolEDIT - If you're a fan of Charles Stross's books, you'll know why I was wistful that the DM's first name was, indeed, Derek
Unfortunately the little GA airplanes I’ve worked on don’t use rig pins-sometimes the manual will give you a pattern for a jig for one part or another of the system (Cessna gives you dimensions for a jig to hold the yoke in the neutral elevator position, Piper gives you a drawing for a jig to set the aileron bellcranks, for example), but usually they have you measure some part of the bellcrank from some other part of the structure, which as you can imagine is a pain in the ass especially with the size of aircraft and the access holes we’re dealing with.I have almost zero GA experience so forgive my ignorance. Do airplanes like a 172 use rig pins? I've changed lots of flight control cables, and without going into a diatribe about the process, installing rig pins into bellcranks or sectors was always considered "zero" and I'll build out from there. The final inspection would always include a visual inspection of everything that had been disassembled, being able to remove/install the pins easily after the cables were tensioned and checking the actual travel of the control surface with a protractor (either mechanical or digital). Inspection of the actual cables was always why they were replaced, @Roger Roger is correct about ordering the cables before you start an inspection. If I'm going to do a tailcone below floor inspection on a G-III I know the cables are going to need replacement because of how the airplane is built, on a G-IV I'll wait until they've been removed and inspected.
Sometimes rigging almost turns into an artistic endeavor. Hydraulically boosted lateral control devices can be problematic. Elevators and rudders normally use one actuator but ailerons require one on each wing and they have to work in harmony as they move in opposite directions, if those girls can't dance together it makes it tiresome for the guy wrestling with the yoke. I've had more than one airplane that came in with a squawk about the ailerons going into "manual reversion" that actually were the actuators not getting along. There's no real base point to start from other than "it's hard to roll right" so the best course of action after verifying the rigging is to make a small change on one of the actuators, if it gets better keep doing it, if it gets worse go back the other way. This is all done in a hangar with at least one hydraulic mule and force gages to measure how much it actually takes to move the yoke. All it takes is time and a bit of an ability to actually "see" the system.Unfortunately the little GA airplanes I’ve worked on don’t use rig pins-sometimes the manual will give you a pattern for a jig for one part or another of the system (Cessna gives you dimensions for a jig to hold the yoke in the neutral elevator position, Piper gives you a drawing for a jig to set the aileron bellcranks, for example), but usually they have you measure some part of the bellcrank from some other part of the structure, which as you can imagine is a pain in the ass especially with the size of aircraft and the access holes we’re dealing with.
It seems the two most informative places to check are if the secondary cables at the ends of the yoke chain are even with each other, and if both aileron bell crank stop bushings are centered in their slots. Depending on the outcome it could be an easy fix (adjusting the push rods between the aileron bellcrank in the wing and the aileron) or a hard fix (re-rigging the cables). It seems like as much of an art as a science, and I’ve only ever watched guys like @Roger Roger and @knot4u do it and have not done it start to finish myself. Note the custom rigging tooling the A&P is expected to fabricate, like the “bar” holding the two yokes together, etc.5. Adjustment/Test
A. Rig Aileron Cables (Refer to Figure 205).
(1) Make sure that the primary cable is in the aft groove of the cable drum and that it is wound once
around the drum.
NOTE: The primary cable lock is installed at the bottom of the drum and the direct cable lock is installed at the top.
(2) With the control wheels in neutral, make sure that the chain ends are approximately equal distances from the center of the sprockets.
(3) With the control wheels in the neutral position, tighten the secondary cable turnbuckles so that the control wheels are level in the neutral position (synchronized). There must be sufficient tension on the cables, but they must also move freely. Results of turnbuckle adjustment are as follows:
(a) When you loosen the secondary cable turnbuckles and tighten the direct cable turnbuckles at the center of the control yoke, the inboard sides of both control wheels move down.
(b) When you tighten one or both of the primary control cable turnbuckles and loosen the secondary cable turnbuckles at the center of the control yoke, the outboard side of the applicable control wheel will move down.
(4) Put a bar in position and attach it with tape across the two control wheels to hold them in the neutral position.
(5) Adjust the direct cable turnbuckles below the control yoke and the single carry-thru turnbuckle at the aileron bell crank so that the bell crank stop bushings are centered in the two bell crank slots with 40 pounds, +10 or -10 pounds (177.93 N,+44.48 or -44.48 N)of tension at 70 °F (21 °C) on the aileron carry-thru cable. Refer to Figure 205 for the correct tensions at other temperatures. Ignore the tension on the direct cables. This tension will be different than the tension on the carry-thru cable.
(6) Adjust the pushrods at the two ailerons until the ailerons are neutral with reference to the trailing edge of the wing flaps. Be sure that the wing flaps are fully up when you make this adjustment.
(7) Remove the bar from the control wheels.
(8) With an inclinometer, do a check of the ailerons for correct travel. Make adjustments if necessary and make sure that the bushing travel stops are correctly centered in the bell cranks.
NOTE: For aileron rigging specifications, refer to Chapter 6, Airplane Dimensions and Specifications - Description and Operation.
(9) Safety all turnbuckles. Refer to Chapter 20, Safetying - Maintenance Practices.
(10) Install all items that you removed for access.
WARNING: Make sure that the ailerons move in the correct direction when you move the control wheel.
(11) Do a check for the correct travel of the aileron.
Because it’s been forever since I worked on a 172, and never did control rigging on one (lots on 206/207) I had to find a picture of the aileron bellcrank and the slot.I know the immediate question is resolved, but for the benefit of future forum lurkers I checked, and Google will readily turn up the PDF(s) for the maintenance manual you seek:
It seems the two most informative places to check are if the secondary cables at the ends of the yoke chain are even with each other, and if both aileron bell crank stop bushings are centered in their slots. Depending on the outcome it could be an easy fix (adjusting the push rods between the aileron bellcrank in the wing and the aileron) or a hard fix (re-rigging the cables). It seems like as much of an art as a science, and I’ve only ever watched guys like @Roger Roger and @knot4u do it and have not done it start to finish myself. Note the custom rigging tooling the A&P is expected to fabricate, like the “bar” holding the two yokes together, etc.![]()
