meritflyer said:I think you meant the PA-30-180 which is the twin Commanche. Typical fuel burn is 12-14 GPH per side.
deserteaglle said:Don't care to hear the specs of a 172m?![]()
I suck.![]()
wheelsup said:sure- what are they? it'll be close to the P model, probably the same
and whatever the PA-XX-160 is, it's a warrior. maybe PA-28-160??
desertdog71 said:Actually its a PA30-160 Twin Comanche and they burn 8 gph each side in cruise.
meritflyer said:Well, yes and no. Miller Modification made a 180 HP and 200 HP version of the Twin Comanche and it burned 12-14 per side.
desertdog71 said:and why would he be asking about a Modded up Twin Comanche as a Trainer?
meritflyer said:Because they're out there in a good amount of numbers. So guess they're not all the 160 HP like you said. Each aircraft model may have several variations such as Piper's PA-28 series which ranged from 160 HP to 235 HP. Our school had 2 Twin Comanches (although I never flew them); a 180 HP and a 200 HP.
desertdog71 said:A C172M is Carbuerated and lower Horsepower. So the nembers aren't the same.
Your Warrior is a PA28-161
If yo wanted numbers on older planes I might be able to help you. I am sure you can do a google for the POH of these aircraft and find the numbers you want.
wheelsup said:Pretty sure the old P models were similar in HP, I'm just looking for a ballpark here - I remember the M models had 40 degress of flaps and the P's had 30 but they were both carbuerated.
I'm just putting some basic specs up here:
web site
That's what I need 'em for.
desertdog71 said:you don't have a POH for these?
Anyways. The numbers look good but I think the P model is actually 42 gallons and 38 useable. They burn around 7 per gallon in cruise, but I usually plan 8 gallons. Actual cruise speed is about 105kts if you are lucky. I don't go longer than 3.5 hour legs for a safe margin on fuel burn, and giving you some leeway for an alternate.
These numbers are based on a C172K and M models.
The K is actually 150hp and 160 for the M.
Also you have the Warrior listed as a PA-34.![]()
wheelsup said:no POH's...thanks for the info and comments...doing these pays the bills and flying is extra.
