Screaming_Emu
Joe Conventional
Be careful out there. It only takes a minute of letting your guard down for bad things to happen.
If you've ever seen these things in a hangar and wondered what they are here's your sign...
large aircraft wheels are essentially split rims, like big rigs?
If true that is a very serious breach of wheel/tire 101.r/aviaitonmaintainence has guys saying that the tire was not depressurized before bringing it into the wheel and brake shop. Two mechanics were disassembling the wheel when the bolts broke and killed them.
I remember dealing with F-18 tires and their full carrier rated pressure was insane.
Correct. In a previous life I worked for a repair station that overhauled wheels. Mostly business aircraft, but also did 737 wheels. Split halves, inflating required use of a cage, lock out tags when valve core removed, etc.
Thanks, now I have something new to be paranoid about.Yep, it is why I don't do walkarounds
That thing doesn't have wheel well doors, right? So you have THAT going for you which is nice, at least.I actually do, do walkarounds but I would be lying if I said that I didn't have a potentially irrational fear of tires and being in the wheel well of the 737. But that being said, the chances of a tire failure on an airplane like this are darn near zero. I am actually more worried I am going to stick my head into the wheel well and have an invisible stream of Skydrol slice through me and kill me.
Nobody needs to get killed at work.
The rumor I am hearing from Delta is that they took the tire in and were disassembling it with it still pressurized. Without enough bolts holding the halves of the wheel together, it exploded apart. Sounds like it was a really bad scene.
