What kind of time is more valuable if you're trying to get into the right seat of a jet?
Single Engine Turbine Time (like a Caravan/Pilatus) or Piston Twin Time (Baron/Cessna 402)
Wanna fight?![]()
The general rule of thumb is multi time gets you on with a regional, captain time at a regional gets you on at a major.
I am going to go with a guy who has PC-12 time over a guy with Baron time. One is a high altitude, high performance, complex, pressurized, glass cockpit aircraft and one is an old skool piston.
I've got about 3000 hours. 2600ish SEL, 400ish MEL. 1200 Turbine (almost all of it PIC). I flew PC-12's and Meridians for 2.5 years. I've since gone on to fly King Airs. I had about 220 hours Multi when I got my current job. While I didnt have much multi, I had a lot of good turbine time.
So, it worked for me. It may not work for everybody though.
that looks like downtown KC in the background of your avatar... looks like the 6B ramp, same background as in my avatar. lol.... you fly outta MKC?
where'd you fly a PC-12?
That is also complex and high performance. And it has that second engine.
I'm just saying...
By sheer definition, I understand.
However, the systems and overall complexity is not comparable, IMO.
I'll argue that an old 414 is more complex than a PC-12. In the PC-12 there are no worries about fuel, cowl flaps, leaning, props, ect. Even the de-ice boots are set on a three toggle switch, blowing at 3 or 5 minutes intervals. Then again, I only have a whopping hour in the left seat of a Pilatus, but it sure seemed a lot less complex than the 414.
I would choose the Pilatus job over a 414 job if everthing else were the same. That airplane is just amazing. I would choose the 414 job over a Caravan or Meridian job though. When it comes to most corporate jobs, the multi requirements are normally much higher than the turbine requirements.
Alex.
