Today's Tech Trivia #2
USMCmech
Today\'s Tech Trivia #2
Man, I'm learning a ton in A&P school, here are some more questions that I think most pilots should be able to answer.
What is the first place that ice will form on the airplane?
Why do airplane engines have two spark plugs? (it's not what ya think)
At what point in the engine cycle has combustion finished? (when has all the fuel that will burn finished burning?)
What is the hottest part of the Cylinder?
If your throttle cable breaks, what will happen and how can you get back on the ground safely?
Answers to follow tonight. /ubbthreads/images/graemlins/cool.gif
Re: Today\'s Tech Trivia #2
I'll give ‘er a go
1) Small protrusions, such as the OAT probe, strut-mounted steps on Cessnas, etc.
2) Redundancy and more complete fuel burn.
3) It usually starts before TDC and ends after the down stroke - still burning in the exhaust manifold sometimes.
4) I would guess the aft side of the cylinder?
5) Not sure - if it's like a car, it would close to idle, but I would imagine it would remain at the same power setting or go to full throttle. Power can be reduced by using only one mag or cutting the mixture
i'll let myself be publicly humiliated .
1. antennae or OAT probe. possibly stall warning flapper if it's piper style?
2. complete fuel burn
3.when you shut off the engine /ubbthreads/images/graemlins/wink.gif
4. spark plug electrode
5. control engine speed as best possible with a combination of mixture, carb heat, and aircraft attitude/airspeed. i wouldn't mess with the mags.
1. I'll go with what the others have said about the airframe, but you can get ice at much higher temperatures in the carburetor.
2. There are several reasons for multiple spark plugs, one is reliability as in most systems there are separate magnetos for each set of plugs. There are some notable exceptions to this such as the Lycoming 'dual magneto' that incorporated both magnetos into one big block with only one drive connected to the engine. Also, quite a few of the old radials had separate distributors, but shared a common magneto to generate current. Another is more power, two plugs lead to more complete combustion, but you can also run a higher compression ratio in a big bore engine if you use two plugs instead of one, without encountering detonation (this is more important in two valve engines that cannot use a centrally mounted spark plug). I think this is probably the best answer, more power and increased detonation margins.
3. I will go with the exhaust stroke. It was common practice in the old days to lean by the color of the exhaust flames coming out of the stacks. So, depending on the mixture setting, it may not be until after the exhaust exits the stack.
4. The spark plug electrode is very hot as is the exhaust valve, but the exhaust port is the hottest part of the actual cylinder. Most of the heat dumped into any engine comes from this location.
5. I believe that the throttle is supposed to go wide open in this case. You would have to modulate engine power with the mixture to land. On a twin you could just feather the engine once established on final. The same happens with constant speed props, they are supposed to go to full rpm if the cable breaks.
Great responses! Thanks guys!
The Carburator. Carb Ice will form well before any surface ice, and if you are picking up ice on the outside, you'll be picking up some in the carb. Carb heat/Alt air is or should be part of any checklist for icing conditions.
Ya'll got this one right! Complete combustion. The piston/cylinder of an airplane engine is so huge (each one has more displacement than most small car engines) that if the flame starts just on one side, it won't burn completly before it should. Since each cylinder needs two spark plugs, engine designers decided to take advantage of the available redundency and use two magnetos.
The spark plugs fire on the compresion stroke about 15-12 degrees before Top Dead Center. All combustion is complete at TDC. The expanding gasses then push down the piston on the power stroke.
The hottest part of the cylinder is the exaust port. The exaust port is identifyed by the greater number of cooling fins around it. The exaust valve gets extreemly hot too.
If the throttle cable breaks the throttle will spring to wide open. If this happens you can reduce power by reducing the mixture. You can depower an engine by starving it for air (closed throttle) or you can starve it for fuel (lean mixture).
Try it sometime, even if you don't buy LOP operations (and I can show you plenty of evidence that LOP is perfectly OK), doing it once or twice won't hurt a thing. Broken throttle cables do happen, and knowing how to controll you airplane like this could save your life.
I'll be back next week with more. /ubbthreads/images/graemlins/cool.gif
What does LOP mean? Im sure if I think hard enough It will come to me....something about Low, power, maybe operations?
Lean Of Peak
(expletetive) /ubbthreads/images/graemlins/grin.gif
Re: Today\'s Tech Trivia #3
Here's some more. /ubbthreads/images/graemlins/cool.gif
Why are partial power takeoffs in piston airplanes extreamely bad? (even if you do have 15,000ft of runway)
What happens to the mixture when you add carb heat?
What indications should you see if your idle mixture is adjusted properly?
Where is the fuel mixed with the air in a typical fuel injected engine?
This one's a toughie! Some A&Ps might have to think a while. /ubbthreads/images/graemlins/confused.gif
Your engine isn't producing full power, vibrations have increased, fuel flow is higher than normal, one cylinder hits peak EGT well before the others, what's wrong?
Correction.
Your fuel injected engine isn't producing full power, vibrations have increased, fuel flow is higher than normal, one cylinder hits peak EGT well before the others, what's wrong?
1. I have no idea, but I've done partial-power takeoffs plenty of times in turbocharged piston aircraft.
2. Enrichens due to the fact that less dense air is now entering the carburator.
3. I'm a little confused on this one. Is this what you're looking for when you're leaning, or when you've already leaned? Anyhoo, I lean to peak (or roughness), then bump the mixture up a bit to make it run smooth again.
4. I'd like to say the intake manifold, but it's been a while since I've gone over this...
5. At first I was thinking you had a clogged injector or something, but that wouldn't explain the higher fuel flow. I dunno. /ubbthreads/images/graemlins/smile.gif
Correction.
fuel injector partially clogged, cylinder running lean due to lack of fuel..so the EGT goes up /ubbthreads/images/graemlins/confused.gif
depends on what type of FI system it is...the cylinder/combustion chamber, intake port of the cylinder
head, or the manifold.
hmm, EGT and cylinder head temp guages reading in the middle green...and no roughness, and you should be able to check it by setting the engine at around 1,000-1,200 RPM and pulling the mixture out slowly...the RPM should rise slightly, but no more than 50 RPM increase before dropping RPM's...if it rises more than 50, its set too rich....no rise at all, set too lean.
On the fuel injected engine - lack of fire in one cylinder?
On the icing question- depends what type of aircraft --
Using partial power will often result in a lean mixture setting at high power, which is not a good idea. Many engines enrichen the mixture when the throttle is fully open. It is never a good idea to use partial power in any aircraft that does not have this procedure in the flight manual. Many mistakenly think that they are 'saving' their engine. This is false economy. The engine will last to TBO if it is operated correctly, and it is safer to use full power. The faster you get off the runway and in the air, the better. Only large jets and turbo-props use partial power takeoffs, and they have the data to support this in their flight manuals.
When you add carb heat, you lessen the density of the intake air. Since most systems meter fuel/air by volume and not density, you will enrichen the mixture. If you intend to run for a long period with carb heat, you should lean the mixture.
When you pull the mixture to idle cutoff to shut down, you should see about a 25 RPM increase in RPM before the engine quits. This shows that you are running slightly rich at full throttle, which is what you want. If you get no increase, you are probably running lean when you use full power for takeoff, which is not good for your engine's, or your longevity.
Most fuel injected engines have constant flow injectors at each intake valve. So the fuel and air is mixed in the intake port. Some of this pools as liquid fuel when the valve is closed, but vaporizes as it is sucked into the cylinder, or as it hits the hot intake valve. In the past some of the largest radials had direct injection, but this is not common. Tne new diesels also inject fuel directly into the cylinder.
One of the fuel injectors is plugged, specifically the one on the lean cylinder. This engine does not really have a 'fuel flow gauge' it has a pressure gauge labelled to show fuel flow. The problem with this is that if one of the injectors is plugged, it will show up as higher than normal fuel pressure. Since the gauge is labeled in GPH instead of PSI, the pilot thinks that fuel flow has increased. This is common on Aztecs, Arrows, older Barons and Bonanzas, and many other aircraft. Most of the high end new production aircraft have had these gauges replaced by fuel flow transducers, which actually measure fuel flow through the line leading to the flow divider on the top of the engine. On some aircraft like older Barons and Bonanzas, the only way to tell what you have is to pull the cowling off and look for the transducer. If you see a dual gauge that shows MAP on one side and Fuel Flow on the other, you probably have one of the older gauges that is actually indicating pressure.
ananoman pretty much covered it! /ubbthreads/images/graemlins/smile.gif /ubbthreads/images/graemlins/cool.gif
Just a couple of nit picks.
At WOT (wide open throttle) the power enrichment valve is opened in the carburator. This increases fuel flow into the venturi. This helps keep the engine cool durring take off and climb. Running at less than WOT is seriously hurting your engine. I personally recomend climbing to cruise altitude at WOT unless your POH says different.
For those flying turbocharged engines with fixed wastegate turbos that can't be opened to WOT. Use the recomended max power setting, this will keep your engine happy for years to come.
At idle the fuel flows on a seprate path than when the throttle is open. It has a seperate metering jet that should be adjusted by a mechanic. This is what I was refering to as Idle Mixture Setting. If you are leaning for ground ops, make sure you run very lean so that you can't inadvertnaly try to take off with a lean mixture.
Re: Today\'s Tech Trivia #4
Here's this weeks bunch. It's kind of short because we've been into complicated stuff that I don't expect most pilots to know. Pressure carbs are just too complex to get into here. /ubbthreads/images/graemlins/confused.gif
Why can't auto gas be used in high altitude aiplane engines? (even if the timing has been adjusted to prevent detonation)
You leave the mixture rich and turn the mag key to OFF. The engine keeps running, what's wrong?
Where does the magneto get it's electricity?
Who is ultimately responsible for the mechanical condition of the airplane?
Next week we do troubleshooting, so I should have some good stuff. /ubbthreads/images/graemlins/smile.gif
I'll have a try....
Octane level too low.
Broken p-lead (not grounding properly)
From the turning of the engine (i.e. dynamo)
The owner/operator
lead acts as a lubricant. without the lead in the gas, the engine doesn't get all the lubrication it's designed to receive. i THINK there were some cases of people converting to mogas and then not making TBO because of valveguide problems dealing with insufficient lubrication. don't quote me.
busted p-lead
it generates its own electricity. the mag is driven by the engine, which in turn, helps the engine run (way simplified, obviously).
the owner/operator
