spoolinup22
Anyone have any little tricks that helped them out with their MEI? I'm doing it in a 1979 Seminole hopefuly by the end of this week.
Study. That's the only trick you need in your kit bag. Study hard, and you'll do fine.
The only other thing I can add is to cast my vote with the others for "study". I cannot remember an instance where anyone failed a check ride for being too well prepared.
I am trying to look into the DPE right now, will I have to fail the engine and he has to recover? Or is it pretty much just me doing my CMEL checkride from the right seat but knowing everything in a whole greater detail?
BTW....when you cut an engine, throttle below 3k agl, mixture above 3k?
Feathering for pilot flight test purposes should be performed only under such conditions and at such altitudes (no lower than 3,000 feet above the surface) and positions where safe landings on established airports can be readily accomplished, in the event difficulty is encountered in unfeathering. At altitudes lower than 3,000 feet above the surface, simulated engine failure will be performed by throttling the engine and then establishing zero thrust.
spoolinup22
Some questions you should be prepared to answer...
Why did you start THAT engine first....?
Is it ever ok to take off below redline?
How do you handle a prop governor failure?
Excellent reminder. BE-76 Duchess is 5,000 AGL and a clear day.remember PTS says 3000 for Vmc demo but piper says 4000
The airplane is a 1979 Seminole, so it does not have the accumulators. I'm not too terribly sure if it has a skytec starter or not...if we can't get it re-started is that grounds for failure?
1. I assume it says in the POH start the left first, something along the lines of its closer to the battery, (i'll look it up once i get the poh)
