Zero1Niner
Have heard the argument both ways. Is it TIME first, or is TURN first?
Which do you use and why.
I thought it was 6 T's
Time
Turn
Twist
Throttle
Trim
Talk
I like that answer.This sounds a lot like do I take a step first or chew my gum first...
I see their point - a couple of seconds of stopwatch accuracy is very important when every other factor is an estimateI asked two of my CFII co-workers today just to see what they said. Man it was comical, they both are very adamant on time being first. They said "when you cruise in something that is 200 knots plus if you don't start the time first before you turn you will miss your point every single time."
I asked two of my CFII co-workers today just to see what they said. Man it was comical, they both are very adamant on time being first. They said "when you cruise in something that is 200 knots plus if you don't start the time first before you turn you will miss your point every single time." Needless to say I rofled on the inside hearing this, I have only been up to a Seminole but entries at 160 were a piece of cake.
IMO if you are incapable of turning the yoke at the same time as pressing a button on a watch then flying isn't for you.
The other reason they gave was, "the order in the book is..." hey tgray is this cognitive dissonance too? Lol
It is amazing that for how smart many pilots are that I speak with there is way to much monkey see monkey do going on. Sure use processes others use, but their process isn't the only one you can and should come up with your own. Who knows in ten years maybe we will be teaching your process, this is how things change and usually it is for the better.
ppragman said:If you're doing a timed approach in an airplane that goes faster than about 170 or so, and you don't have DME or at least some other sort of system to back you up you're probably working for the wrong company. If you're flying in the flat lands and there's nothing to hit its one thing, however, I'd be a little reticent to be driving down on the approach at 200kts on time alone
That's the AF version? Explain True and Token. I'm assuming Tires is gear down (like at the FAF?)You're all wrong. The correct order is:
Throttle
Talk (and receive acknowledgement)
Time
Twist
Turn
Track
True
Teach
Tires
Token
Throttle
Time
Twist
Turn
Track
True
Teach
Tires
Token
