chris
Hey guys,
I don't understand why thrust available decreases with increasing airspeeds. I know it has something to do with the fact that the props lose efficiency as you go faster... but why is this?
I have read that the relative wind changes (and hence the AOA changes) as you go faster... the faster you go, the more the AOA decreases, and thus the amount of thrust produced decreases. But why is the RW changing?
On a similar note... Fine pitch props are not good for cruising and lose efficiency at high speeds. Is this because the pitch (and hence AOA) is relatively low on this setting, and thus, not much thrust is produced?
Thanks.
Thanks.
