Thinking about joining Pan Am...
Richard
I have been looking at Pan Am for awhile and have about 80% decided to attend. I have sent in the application and am awaiting to receive my enrollment packet for the January class. I am going to visit the academy at the beginning of November. Is there any advice for a new student coming to town? Any help would be greatly appreciated!!
Phoenix_Son
I don't know much about the school, but I know the area around the airport pretty well. That region between Phoenix and Cave Creek is a funny one. There are some awfully run-down areas up there, and some gorgeous communities. Take your time on the apartment hunt and you should find some great deals. If you need academic credits (I don't know if you're pursuing a degree, or just ratings), there's a decent community college southeast of the airport, near the 51 freeway. ASU is about an hour away from Deer Valley.
It can be rainy in January and February, but then it's sunny nearly every day until the monsoons in late July & August. I've heard that DVT is pretty busy from all the student pilots. It's the only two-runway airport for quite a few miles in any direction.
Richard
Thank you for the information, but I should have specified that I will be attending the Ft. Pierce campus if I decide to attend. Anyways, a little about me... I am 26, I have a B.S. in psychology and have established a decent career.... but I have decided to follow my dream before it gets to be too late
A couple of quick questions... about how many hours a month do you get to fly as a flight intructor? Also, since you cannot work full time, health insurance would become an issue.... is there anything on campus such as an infermory to take care of this need? Thanks for all your help!
Lima_Charlie
I am in the midst of my private at the Phoenix campus, and have a couple of tips I received before starting. If you are starting w/ Zero time, then I would pick up the Jeppesen Private Pilot manual and get reading. The learning curve is VERY steep, and if you can come in w/ some knowledge, then the concepts won't seem so foreign and, you will give yourself a much better chance of staying on budget, both in time and money. Hope this helps...
Lima_Charlie
You know, as simple a question as that is, it is hard to explain. At times it AMAZES me how high the expectations are! The pace of the program seems quite overwhelming at times. The expectation is that you will be proficient at whatever new maneuver or concept you are taught after one or two lessons. If not, then you have to repeat the lesson until you "get it". So, in the long run, that can get expensive! Overall, I think the program is VERY demanding, and if you are not committed to it for the long haul, then it will be a very rough and frustrating trip. You are truly at the mercy of the school. You have VERY little control over your schedule, which leaves very little time for a "life" outside of school.
As far as my training goes, I came in with zero time, and have been keeping up with most of the people that have come in w/ 30-40 hours of experience. So I think my training has gone well, so far. Some days are great, others not so great... :)
Phoenix_Son
Thanks for the advice - I bought it on amazon once I read your post.
The other book I've seen recommended on jc is "Aerodynamics for Naval Aviators." It's supposedly a good 'intro to aerodynamics' textbook, so I bought that as well.
pure_IMC
aerodynamics for naval aviators is a little much in my opinion, especially if you are just starting out. It is very complex, and for the most part caters to jet aircraft. I would recommend to anyone to just check it out at the library and see if you want it. Thats what I did, and I chose not to buy it, and this was after I had all my ratings. Stick with the Jeppesen in the early going, or you may just confuse yourself.
Lima_Charlie
A couple of other books you might want to pick up are The Pilots Handbook of Aeronautical Knowledge, and the AirplaneFlying Handbook. Both are FAA publications and go right along w/ what you will read in the Jepp PPM. Oh and they are two of the books you will have to buy when you start anyway. If you want more to read, pick up the Aviation Weather Services book and Aviation Weather. Weather can be a challenge for some people because there is so much to know. Have fun reading!
Lima_Charlie
Be careful when buying books on Amazon and such. Try to make sure you are getting the current edition. The latest Jeppesen PPM is tan and published in 2002.
Just a little tip....
Phoenix_Son
Uh-oh. That was pretty naive of me.
It's the 1999 edition. Have you seen the 2002 edition? Is it different enough to be worth cancelling my order?
Lima_Charlie
Yes, I do have the 2002 edition, but I don't have the 1999 edition to compare it to. If you can find 2002 edition, and can cancel the 1999 edition, w/o any penatly, I would do it. If not, I can't imagine that the information is that different between the two. Unfortunately, you would want to have the most current edition before you start training, just to be safe.
perpetual
Richard, Do you really want to spend 80,000+ dollars?
You should take a look at an fbo, or Ari-ben aviator..
you can get the same ratings, and yes (same quality of training) for 10's of thousands of dollars less.
Seriously think about that... many here know that spending 80,000 $
is rediculous when you can spend as little as 25,000$.
Its kinda like going to the store A.) and getting those pair of Nike shoes for 150 bucks,
or.. going to an outlet store and getting the same pair for 20$.... Which one makes more sense?
-Perpetual
panampilot
or.. going to an outlet store and getting the same pair for 20$.... Which one makes more sense?-Perpetual
Not really but nice try.
perpetual
To be frank... Are you an Idiot Panampilot?
I'll say it again, and hopefully you can grasp
the concept okay? Perhaps my "wording" was confusing for you.
Heres the example re-written to hopefully "clear things up".
Store A.) Sells brand "x" product for 100$
Store B.) "also" sells brand "x" product for only 10$
It does not take quantum mechanics to figure out
that "if you want the same product for "less" money goto Store B.
It amazes me to see how some people simply do not
grasp these "very high level discussions" lol
Oh and just to verify, I have experience with Pan Am
as well as the FBO route.
You can save 10's of thousands of dollars in an FBO.
(and yes still make it to an airline)
Lima_Charlie
Well, here we go!! I was begining to wonder how long it would take for the insults to begin. As you will come to understand, there are a handful of people that are on a mission to slay the the mighty dragon, called the ACADEMY!!! :)
The big question for you is, where do you see yourself training and why? I am sure an FBO has some advantages, and those advantage will appeal to certain people. I am sure an FBO is cheaper, but I question whether or not you can get through all the ratings in the same amount of time. Then you have the quality of the training. I have a hard time believing that the average local FBO w/ 10-15 students would be able to provide the level of training that a big academy could. But that is just an opinion.
I know that in my class of about 20 students, 10 came in w/ previous FBO training experience, and still decided to invest the big $$$ in an academy.
I think that if one just want to learn how to fly, then an FBO is a great place to learn. But if one want to fly as an airline pilot, your best bet is w/ an academy. (Yes, yes... I am sure that many an airline pilot has come from an FBO, but I would venture a bet that the Academy has put out many more.)
Just my two cents...
MikeD
Administrator
Staff member
How fast you get your ratings has no bearing on whether an Academy is better or worse than an FBO. You can go through an FBO and if you market yourself well, or apply at the right time (timing is everything), you'll have the same opportunity. "Getting to the finish line first" ratings-wise isn't everything. I wonder sometimes about the guy studying for his ATP while finishing up his Private, long before he's even had time to absorb being a Private Pilot. Plus, $$$ doesn't necessarily equal quality. Not necessarily referring to PanAm here, just in a big-picture sense.
MD
perpetual
JoJo, I hope that you can see the obvious reason as to my "response" towards "Panampilot".
The utter and sheer foolishness on his part to seemingly grasp the concept that you can get
the same ((yes same exact)) training for a less ((yes less costly)) school/fbo was the point.
Here is some thing for you To chew on JoJo. I have been to "Pan Am International Flight Academy"
and do you know what? Their CFI's MEI's, and CFII's have the "SAME" level of knowedge of those
instructors that I have met/known/received instruction from other "schools/Fbo's" etc.
Here is the 1 FACT that everyone here needs to "fully" realize
"Learning depends upon the student" It doesnt matter if you have a 50,000 Hr instructor pilot,
or a newly minted CFI teaching the student. It "ultimantly" comes down to how well the student:
A.) wants to learn, and B.) Is able to learn.
Whats the point? Well here's the important fact: If you are motivated, and want to acheive what
you set out to acheive you will do so. And it makes ALL the sense in the WORLD to Spend as
"LITTLE" as possible to get where you want to be.
That is of course if you like burning money away.
panampilot
Are you done insulting me?
I have nothing against going to an FBO but I do not agree that you get the same training from an FBO than you do from an academy. I know because I've done both and I have experience with both. I am not arguing quality of training here. There are some CFI's that have a billion hours that have a whole lot more knowledge than I do that work at Ma and Pa FBO's. The quality may very well be the same, here is why I think the Academy training gives you more for MORE money:
1. Brand new aircraft; this may not be important to most but it was for me because I was sick of planes breaking down all the time and I was wasting my time waiting for them to be fixed.
2. Airline style training; again may not be important to others but it was to me. Pan Am has a bi-annual meeting with executives from many different airlines that meet and discuss what type of skills they would like to see in pilots when they come to groundschool. How many FBO's teach Vref and Vtarget airspeeds for approaches? Mine didn't.
3. A jet transition course. This course is set up to mimic an airline groundschool. It is the most I have ever studied including college. It was brutal. But, now I know what to expect and I feel like I have a heads up on others that might be in the same groundschool as myself. This course is taught by airline pilots not by Joe Schmo.
4. Job placement. Academies are able to set up agreements with airlines to hire their graduates with lower times than others. It happens on a regular basis here at Pan Am.
5. Multi time. I know FBO's have twin engine planes but most academies have a program set up where you can do line oriented flight training. This gives you experience flying all over the country in a two crew environment honing your skills. Not to mention that as an instructor I have over 500 multi hours now. That is virtually unheard of from anyone instructing at an FBO.
There are may other reasons I chose to go to an academy. I paid a premium price for the options I listed above. I found those important to me. They might not be for others. So to some things up PERPETUAL, the FBO route is perfectly fine but don't go bashing others who chose to go this route. To all his own.
