For those of us that are older than petrified dinosaur turds, it would cause the beacon targets to "blossom." I don't know if there are any facilities like that left.
Since we're talking old school. While on the jet penetration for a HI-VOR/TACAN IAP a number of years back, ATC requested "Ghost 12, Squawk LO, present code" to me. I hadn't heard that since the mid-80s, and even then only one other time in my career.
On ACD, if you look at the inset pic of American 176, it causes ID to flash in white letters in the space the T occupies to the right of ground speed if the target is on an assigned code. Even if you're squawking 1200 and ident on accident the ID pops up, I believe below your altitude which is all ACD displays without a slew on a 1200 code aircraft.
Nothing at all wrong with that. Someday, if you work hard enough, it actually comes in slightly handy.Awesome. Thanks a lot for the detailed responses guys, I love to nerd out over this stuff. (<- Ex. MS Flight Sim/VATSIM enthusiast. Don't taze me bros.)
We used to use that fairly regularly at one of my non-automated career stops, mostly to prevent (or lessen) "ring around." My understanding is that improvements in technology were such that they don't even make transponders with low sensitivity settings any more.
5-2-12. STANDBY OR LOW SENSITIVITY OPERATION
You may instruct an aircraft operating on an assigned code to change transponder to “standby” or “low sensitivity” position:
NOTE-
National standards no longer require improved transponder to be equipped with the low sensitivity feature. Therefore, aircraft with late model transponders will be unable to respond to a request to “squawk low.”
a. When approximately 15 miles from its destination and you no longer desire operation of the transponder.
b. When necessary to reduce clutter in a multi-target area, or to reduce “ring-around” or other phenomena, provided you instruct the aircraft to return to “normal sensitivity” position as soon as possible thereafter.
PHRASEOLOGY-
SQUAWK STANDBY,
or
SQUAWK LOW/NORMAL.
[SIZE=-2]
REFERENCE-
FAAO JO 7110.65, Para 5-3-3, Beacon Identification Methods.[/SIZE]
I had never heard of "Squawk Low," so you got me digging around in the 7110.65 and I found this:
"N27GM, LA Center, over"
"LA Center, VariEze 27GM, go ahead"
"N27GM, you appear to have been squawking ident for the past 30 miles, can you check your transponder?"
"Roger, it looks like my knee was caught on the ident button, sorry about that, VariEze 27GM."
"N27GM say again?"
If we ident the transponder,the ATC could see us on the radar screen with flash dot,right?
