My Flight Surgeon
Sr. Aviation Medical Examiner
This is the last in the series of condition for which the FAA grants Special Issuance certificates.
As with all other conditions, the FAA will want to review the entire medical record. Your AME or www.faaspecialissuance.com can assist you in preparing your records for submission.
The topic today is Testicular carcinoma.
[FONT="]Testicular cancer[/FONT]
[FONT="]Testicular cancer is a disease in which cells become malignant (cancerous) in one or both testicles. [/FONT]
[FONT="]The testicles (also called testes) are a pair of male sex glands. They produce and store sperm and are the main source of testosterone in men. These hormones control the development of the reproductive organs and other male physical characteristics. The testicles are located under the penis in a sac-like pouch called the scrotum. [/FONT]
[FONT="]Based on the characteristics of the cells in the tumor, testicular cancers are classified as seminomas or nonseminomas. Other types of cancer that arise in the testicles are rare and are not described here. Seminomas may be one of three types: classic, anaplastic, or spermatocytic. Types of nonseminomas include choriocarcinoma, embryonal carcinoma, teratoma, and yolk sac tumors. Testicular tumors may contain both seminoma and nonseminoma cells. [/FONT]
[FONT="]Testicular cancer accounts for only 1 percent of all cancers in men in the United States. About 8,000 men are diagnosed with testicular cancer, and about 390 men die of this disease each year (1). Testicular cancer occurs most often in men between the ages of 20 and 39, and is the most common form of cancer in men between the ages of 15 and 34. It is most common in white men, especially those of Scandinavian descent. The testicular cancer rate has more than doubled among white men in the past 40 years, but has only recently begun to increase among black men. The reason for the racial differences in incidence is not known. [/FONT]
[FONT="]Risk factors [/FONT]
[FONT="]The exact causes of testicular cancer are not known. However, studies have shown that several factors increase a man’s chance of developing this disease.[/FONT]
[FONT="]Most testicular cancers are found by men themselves. Also, doctors generally examine the testicles during routine physical exams. Between regular checkups, if a man notices anything unusual about his testicles, he should talk with his doctor. Men should see a doctor if they notice any of the following symptoms:[/FONT]
[FONT="]Diagnosis[/FONT]
[FONT="]To help find the cause of symptoms, the doctor evaluates a man’s general health. The doctor also performs a physical exam and may order laboratory and diagnostic tests. These tests include:[/FONT]
[FONT="]Although the incidence of testicular cancer has risen in recent years, more than 95 percent of cases can be cured. Treatment is more likely to be successful when testicular cancer is found early. In addition, treatment can often be less aggressive and may cause fewer side effects.[/FONT]
[FONT="]Most men with testicular cancer can be cured with surgery, radiation therapy, and/or chemotherapy. The side effects depend on the type of treatment and may be different for each person. [/FONT]
[FONT="]Seminomas and nonseminomas grow and spread differently and are treated differently. Nonseminomas tend to grow and spread more quickly; seminomas are more sensitive toradiation. If the tumor contains both seminoma and nonseminoma cells, it is treated as a nonseminoma. Treatment also depends on the stage of the cancer, the patient’s age and general health, and other factors. [/FONT]
[FONT="]The three types of standard treatment are described below. [/FONT]
[FONT="]Men with testicular cancer should discuss their concerns about sexual function and fertility with their doctor. It is important to know that men with testicular cancer often have fertility problems even before their cancer is treated. If a man has pre-existing fertility problems, or if he is to have treatment that might lead to infertility, he may want to ask the doctor about sperm banking (freezing sperm before treatment for use in the future). This procedure allows some men to have children even if the treatment causes loss of fertility.[/FONT]
[FONT="]FAA Special Issuance[/FONT][FONT="]
AME Assisted Special Issuance (AASI) is a process that provides Examiners the ability to re-issue an airman medical certificate under the provisions of an Authorization for Special Issuance of a Medical Certificate (Authorization) to an applicant who has a medical condition that is disqualifying under Title 14 of the Code of Federal Regulations
(14 CFR) part 67.
An FAA physician provides the initial certification decision and grants the Authorization in accordance with 14 CFR 67.401. The Authorization letter is accompanied by attachments that specify the information that treating physician(s) must provide for the re-issuance determination. If this is a first time issuance of an Authorization for the above disease/condition, and the applicant has all of the requisite medical information necessary for a determination, the Examiner must defer and submit all of the documentation to the AMCD or Regional Flight Surgeon for the initial determination.
Examiners may re-issue an airman medical certificate under the provisions of an Authorization, if the applicant provides the following: [/FONT]
- [FONT="]Undescended testicle (cryptorchidism): [/FONT][FONT="]Normally, the testicles descend from inside the abdomen into the scrotum before birth. The risk of testicular cancer is increased in males with a testicle that does not move down into the scrotum. This risk does not change even after surgery to move the testicle into the scrotum. The increased risk applies to both testicles.[/FONT]
- [FONT="]Congenital abnormalities: [/FONT][FONT="]Men born with abnormalities of the testicles, penis, or kidneys , as well as those with inguinal hernia (hernia in the groin area, where the thigh meets the abdomen), may be at increased risk. [/FONT]
- [FONT="]History of testicular cancer: [/FONT][FONT="]Men who have had testicular cancer are at increased risk of developing cancer in the other testicle. [/FONT]
- [FONT="]Family history of testicular cancer: [/FONT][FONT="]The risk for testicular cancer is greater in men whose brother or father has had the disease. [/FONT]
- [FONT="]a painless lump or swelling in a testicle[/FONT]
- [FONT="]pain or discomfort in a testicle or in the scrotum [/FONT]
- [FONT="]any enlargement of a testicle or change in the way it feels [/FONT]
- [FONT="]a feeling of heaviness in the scrotum [/FONT]
- [FONT="]a dull ache in the lower abdomen, back, or groin [/FONT]
- [FONT="]a sudden collection of fluid in the scrotum [/FONT]
- [FONT="]Blood tests [/FONT][FONT="]that measure the levels of tumor markers. Tumor markers are substances often found in higher-than-normal amounts when cancer is present.[/FONT]
- [FONT="]Ultrasound, [/FONT][FONT="]a test in which high-frequency sound waves are bounced off internal organs. Their echoes produce a picture called asonogram. Ultrasound of the scrotum can show the presence and size of a mass in the testicle. It is also helpful in ruling out other conditions, such as swelling due to infection or a collection of fluid unrelated to cancer. [/FONT]
- [FONT="]Biopsy [/FONT][FONT="](microscopic examination of testicular tissue by a pathologist) to determine whether cancer is present. In nearly all cases of suspected cancer, the entire affected testicle is removed through an incision in the groin. If testicular cancer is found, more tests are needed to find out if the cancer has spread from the testicle to other parts of the body. Determining the stage (extent) of the disease helps the doctor to plan appropriate treatment. [/FONT]
- [FONT="]Surgery [/FONT][FONT="]to remove the testicle through an incision in the groin is called a radical inguinal orchiectomy. Men may be concerned that losing a testicle will affect their ability to have sexual intercourse or make them sterile (unable to produce children). However, a man with one healthy testicle can still have a normal erection and produce sperm. Therefore, an operation to remove one testicle does not make a man impotent (unable to have an erection) and seldom interferes with fertility (the ability to produce children). For cosmetic purposes, men can have a prosthesis (an artificial testicle) placed in the scrotum at the time of their orchiectomy or at any time afterward. [/FONT]
- [FONT="]Radiation therapy [/FONT][FONT="]uses high-energy rays to kill cancer cells and shrink tumors. It is a local therapy, meaning that it affects cancer cells only in the treated areas. External radiation (from a machine outside the body), aimed at the lymph nodes in the abdomen, is used to treat seminomas. It is usually given after surgery. Because nonseminomas are less sensitive to radiation, men with this type of cancer usually do not undergo radiation therapy. [/FONT]
- [FONT="]Chemotherapy [/FONT][FONT="]is the use of anticancer drugs to kill cancer cells. When chemotherapy is given to testicular cancer patients, it is usually given as after surgery to destroy cancerous cells that may remain in the body. Chemotherapy may also be the initial treatment if the cancer is advanced; that is, if it has spread outside the testicle at the time of the diagnosis. [/FONT]
- [FONT="]Chemotherapy is a systemic therapy, meaning drugs travel through the bloodstream and affect normal as well as cancerous cells throughout the body. The side effects depend largely on the specific drugs and the doses. Common side effects include nausea, hair loss, fatigue, diarrhea, vomiting, fever, chills, coughing/shortness of breath, mouth sores, or skin rash. Other side effects include dizziness, numbness, loss of reflexes, or difficulty hearing. Some anticancer drugs also interfere with sperm production. Although the reduction in sperm count is permanent for some patients, many others recover their fertility. [/FONT]
(14 CFR) part 67.
- [FONT="]An Authorization granted by the FAA; and[/FONT]
- [FONT="]A current status report performed within 90 days that must include all the required followup items and studies as listed in the Authorization letter and that confirms absence of recurrent disease.[/FONT]
- [FONT="]There has been any recurrence of the cancer; or[/FONT]
- [FONT="]Any new treatment is initiated[/FONT]
